K24 swap in a RSX w/ stock ecu
Old Dec 7, 2005 | 09:05 PM
K20Z3CivicSiVTEC's Avatar
Default K24 swap in a RSX w/ stock ecu
i was wondering would there b a problem using a k24 w/ a stock Type S ecu?
Old Dec 8, 2005 | 11:23 AM
eff sea's Avatar
Default Re: K24 swap in a RSX w/ stock ecu (K20Z3CivicSiVTEC)
I would guess so, since the extra .4 liters of displacement probably DO make a difference
Old Dec 9, 2005 | 07:27 AM
HexLoco's Avatar
No way you can do that!!! ECU is only about $250.It has to to with Shift points,timing maps etc.
Old Dec 9, 2005 | 07:35 PM
whiteb16crx's Avatar
Default Re: K24 swap in a RSX w/ stock ecu (HexLoco)
ok if you put the whole k24 with the k24 head with type s ecu no you can't because the type s has real vtec and the k24 has bulshit vtec. if you use k24 block with type s head and type s ecu then yea you can. the beat way is just use the k24 block and type s head with ecu.
Old Dec 9, 2005 | 08:51 PM
yeah sorry i should of said this earlier but i was talking about the k24 out of the TSX if that helps
Old Dec 9, 2005 | 11:03 PM
.Thomas's Avatar
it does work, but not well, like shift early, and just drive to 7-11 and then get it tuned, not good for a long time SCC had an article on this i think.
Old Dec 12, 2005 | 07:17 AM
Nikos's Avatar
No, don;t do it.. Unless you are one of these guys that buy rolex but still take the bus to work
You need K pro with it or AEM EMS
chessboxer
12
Jun 24, 2009 06:58 AM
91EF9hatch
Sep 8, 2008 06:09 PM
Andrie Hartanto
Aug 2, 2004 03:47 PM
jwad1584
Aug 12, 2003 06:50 PM
