clock wiring **HELP**
Old Dec 7, 2005 | 08:15 PM
Hella_Fresh's Avatar
Default clock wiring **HELP**
my clock is not hooked up. It looks like there is no harness or anything for it.
Does anyone know where to look excatly for it?
Or
Where would the wires be located and what colors are they??
thanks
Old Dec 7, 2005 | 11:55 PM
Default Re: clock wiring **HELP** (sXekid)
helppppppppppppp
Old Dec 8, 2005 | 07:12 AM
hatchinprogress's Avatar
the harness should be in the dash(even if the car didnt have a clock) i dont remember the colors (but its 2 wires so prob red and black) if you need 1 i can get you a harness and clock so let me know
Old Dec 8, 2005 | 09:38 AM
zccr-xsi's Avatar
ull also need an all time power wire hooked to it cause i wired mine to the dash harness.it works but when i shut my key off it goes off and then resets itself.
Old Dec 8, 2005 | 06:19 PM
Default Re: (vteckillenzc)
yea see i have a clock in the car, theres just no hook up at all!
ill take a good look under the dash tomorrow.
Old Dec 8, 2005 | 06:40 PM
dorko-t's Avatar
i have a HF crx...and i got a clock from a friend for 1$, and i took the stock HF air vents off and there was a plug in the very left side of the dash (inside the hole)...and all i did was plug it up, and set the time...
very very easy mod
Old Dec 8, 2005 | 07:28 PM
zccr-xsi's Avatar
Default Re: (sXekid)
u should have like 2 or three wires back there.with a clip.thats if it wasnt cut off.anyone have a wiring dirgram from the chassis harness??if so please post it up,or even a link to one would work.
Old Dec 8, 2005 | 08:57 PM
Sick79's Avatar
There will be a plug behind the center vent, both of my dxs' didnt have clocks and the plug was still there stuck into the little clock block off plate. U have to unscrew the plate, and the clock just bolts in and looks 100% stock.
Old Dec 9, 2005 | 06:26 AM
civicslayrx's Avatar
remove your center?shift consol, then *pop* out the vents/clock that sits above the centerconsol, look hard in the cavitie behind the dash. There should be a harness in there that plugs into your clock.
Old Dec 9, 2005 | 07:21 AM
zccr-xsi's Avatar
yea i know where its at but the plug been cut.i need dirgram?
Old Dec 9, 2005 | 01:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">yea i know where its at but the plug been cut.i need dirgram?</TD></TR></TABLE>
yea i know where to find the plug and i know what it looks like. but i think it has been cut by the previous owner.
Now i just need to know where to wire the 3 wires at because i can go get a plug at a junk yard.
Old Dec 9, 2005 | 09:45 PM
EF_338's Avatar
is thier a plug in the center air vent of the STD models as well cause ive been wanting to put in a clock ??
sorry dont mean to thread jack
Old Dec 9, 2005 | 10:14 PM
Zero2SixtySound's Avatar
Do you have the wires coming through the inner dash where there is a hole for them (located on the left side when facing the dash behind the center vent)? If there are wires still sticking through, you should have 4. The colors are as follows: White w/blue stripe; Red w/black stripe; Yellow; Black.
4 Wires connect into my clock. I have a 90 Hatch.
When you get the junkyard plug, try to keep some wire so you can match them up.
Otherwise...
For positioning purposes, connect the plug to the clock and have the clock facing you as if it were mounted (keep it in this position to use my sequence below). Now that you have the plug in the right position, the wire sequence is as follows:
Top right: White w/blue stripe
Top left: Yellow
Bottom right: Red w/black stripe
Bottom left: Black
I hope that helps. Good luck.
Old Dec 10, 2005 | 09:06 AM
Floored's Avatar
Default Re: (EF_338)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_338 &raquo;</TD></TR><TR><TD CLASS="quote">is thier a plug in the center air vent of the STD models as well cause ive been wanting to put in a clock ??
sorry dont mean to thread jack</TD></TR></TABLE>
There should be, I havent pulled that section in my car, but I know my car was pre-wired for a cigarette lighter as well as rear speakers. So I would assume it is also pre-wired for the clock.
Old Dec 10, 2005 | 03:32 PM
Default Re: (Floored)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floored &raquo;</TD></TR><TR><TD CLASS="quote">
There should be, I havent pulled that section in my car, but I know my car was pre-wired for a cigarette lighter as well as rear speakers. So I would assume it is also pre-wired for the clock. </TD></TR></TABLE>
i think all of them are pre wired, you just have to pull it throught.
i will check mine today and see waht i can do.
Old Dec 10, 2005 | 04:26 PM
I Have an STD's Avatar
wrenchin'
had a clock and a cig lighter in my blue std. just hooked em up, all wiring was there. i have a lighter in the new std, just havent found a free clock yet!
Old Dec 24, 2005 | 06:53 AM
Default Re: (I Have an STD)
**update**
ok so i found the 4 wires that the plug is supposed to be on....
well they were all cut, there isnt a plug there anymore.
but atleast i found the wires so i can get a plug and wire it up.
jdmd15crx
72
Feb 11, 2015 02:02 PM
Lexxi_TegK24
Dec 4, 2012 02:32 PM
usdm.ehtu
Mar 17, 2007 07:54 PM
Expletive!
Aug 16, 2006 04:17 PM
