oil leak help!
i have a leak on my d16z6, its not very big at all. just enough to lightly coat the top panel of my tranny. it seems to be coming from somthing thats under the distributor. i dont know exactly what it is. i hope you guys can help. thanks!
could be your distributor O-ring. to fix that, you need to buy a new O-ring.
1. make a mark across the 2 surfaces where the bolt goes through connecting the dizzy to the head. (you're going to use this as a reference later when you re-install it)
2. loosen and take out 3 dist. bolts.
3. pull the dist. out of the head and take off old O-ring.
4. re-install new O-ring
5. line up the 2 teeth of the dist. to the cam shaft and re-install your dist.
6. remember the mark you made? line it up and tighten the 3 bolts.
jawsiiv
Nov 21, 2008 05:43 PM
