my 10sec b16 engine build for the hatch 56k take a nap...
Old Dec 7, 2005 | 07:21 PM
89B16Civic's Avatar
Default my 10sec b16 engine build for the hatch 56k take a nap...
Well ive been buying everything for my engine thats going in the hatch for about a year now so i figured it was time to post up the progress of it so far.. Heres the spec's on my engine...
Engine block prep. JGE PRO SERIES B16A STROKER (1937cc)
Hot tank and clean yes
Step deck yes .0015
Resleeve yes / JGE ductile iron
Bore cylinders Yes to 84mm
Power hone Yes, finished with sunnen AN300 stones
Deck block surface yes / with step to maximize head gasket seal
Crankshaft 89.0mm
Balance Yes, ultra balanced
Main bearings Yes, using hand lapped oe bearings pink
Rod bearings Yes, using hand lapped oe bearings pink
Thrust bearings yes
Oil pump New type R oil pump with billet gear
Seals and gaskets yes
Con rods JGE Light weight I beam
Pistons CP race pistons
Piston size 84mm
Comp ratio 9.0
Ring pack JGE custom
Head studs ARP torque two steps. 50 / 70 psi.
Head gasket Cometic .051
Timing belt New belt
Camshafts 296 / 300 vt
Port work Full competition port and polish 295+cfm ports
Intake valve guides Tapered
Exhaust valve guides Tapered down
Valve spring retainers JGE light weight titanium retainers
Valve springs JGE dual spring high rev kit.
Valve job Full radius intake and 3 angle exhaustIntake valves JGE stainless steel 34.0
Exhaust valves JGE stainless steel 28.0
Valve seals New
Chambers polished / cced
Cleaning Hot tanked
Please if you have anything bad to say about JGE's service or engine building please keep it out my thread i have delt with them for a long time and have had no problems with them
YS1 fully rebuilt with type R lsd....
Full Race turbo mani...
GT35R
3in dp
bunch of misc still there is a lot more stuff laying around i just dont have pics of it...
A old *** pic of the hatch. Right now the hatch is completly tore down there isnt much left. In the next couple days i will add some more pics of everything in doing to interior and some more pics of the engine setup.. thanks
Modified by 89B16Civic at 9:26 PM 12/7/2005
Old Dec 7, 2005 | 07:25 PM
Jonathan_ED3's Avatar
Very cool!
If you don't mind me asking, what's your total investment?
Old Dec 7, 2005 | 07:29 PM
89B16Civic's Avatar
Default Re: (Jonathan_ED3)
Im guessing its right around 15 grand right just for all the engine stuff. Ive spent a good amount of money on interior pieces to but i havnt really kept track.
I try not to keep track so i dont **** myself off with all the money ive spent...
C1CRX's Avatar
Traffic signal tech
Default Re: my 10sec b16 engine build for the hatch 56k take a nap... (89B16Civic)
Looks like its gonna be a monster keep us updated on how it all goes
Old Dec 7, 2005 | 07:31 PM
89B16Civic's Avatar
Default Re: my 10sec b16 engine build for the hatch 56k take a nap... (lvcrx)
will do
Old Dec 7, 2005 | 07:36 PM
Boosted Chemist's Avatar
nice setup, whats the crank out of ? an ls?
Old Dec 7, 2005 | 07:37 PM
89B16Civic's Avatar
Default Re: my 10sec b16 engine build for the hatch 56k take a nap... (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">nice setup, whats the crank out of ? an ls?</TD></TR></TABLE>
yes
Old Dec 7, 2005 | 07:38 PM
Default Re: (89B16Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89B16Civic &raquo;</TD></TR><TR><TD CLASS="quote">Im guessing its right around 15 grand right just for all the engine stuff. Ive spent a good amount of money on interior pieces to but i havnt really kept track.
I try not to keep track so i dont **** myself off with all the money ive spent... </TD></TR></TABLE>
What kind of interior pieces? OEM Honda?
Old Dec 7, 2005 | 07:42 PM
89B16Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">
What kind of interior pieces? OEM Honda?</TD></TR></TABLE>
yeah im going to run full interior and everything in the interior was pretty much shot when i bought the car , plus im getting a 6pt roll cage. There some other things im going to do to it to i just havnt got that far yet ive been trying to finish up getting all the things i need to get this engine in...
Old Dec 7, 2005 | 07:51 PM
crxnj's Avatar
This is what I like seeing..
What kind of ems are you gonna be using,,?? and whats your hp goal ,like 600-650??
Old Dec 7, 2005 | 07:53 PM
89B16Civic's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">This is what I like seeing..
What kind of ems are you gonna be using,,?? and whats your hp goal ,like 600-650??</TD></TR></TABLE>
As of right now im just going to go with hondata but im thinking of going with AEM. Hp goals well ill be happy with 500 but i think its going to end up going higher then that.
Old Dec 7, 2005 | 08:00 PM
crxnj's Avatar
As of right now im just going to go with hondata but im thinking of going with AEM. Hp goals well ill be happy with 500 but i think its going to end up going higher then that. </TD></TR></TABLE>
Yeah I can't see doing all that work for 500hp..I hope you make atleast 600hp out of it..What are the specs on that gt35r..?
Old Dec 7, 2005 | 08:13 PM
89B16Civic's Avatar
Yeah I can't see doing all that work for 500hp..I hope you make atleast 600hp out of it..What are the specs on that gt35r..?</TD></TR></TABLE>
Yeah when i started it all i just wanted 500 but now who knows i guess ill just have to see how it goes
and the specs on the gt35r i went with the 0.82 a/r and it has a 0.70 a/r compressor housing on it. Good to over 600hp
Old Dec 7, 2005 | 08:47 PM
gen2fanatic's Avatar
this dude isnt ffuckin around haha... hope your de-ricing... but to each his own. looks like a badass setup bro... let us know what she runs
Old Dec 7, 2005 | 09:06 PM
Jesterian's Avatar
24.243.141.75
Default Re: (gen2fanatic)
Crazy car.. 5-600 hp in a 2klb car is gonna be insane.
Old Dec 8, 2005 | 01:34 AM
Twilight's Avatar
Default Re: (Jesterian)
Looks great, keep the good work up. And keep us updated.
Old Dec 8, 2005 | 03:07 AM
hellshock2182's Avatar
My motto for building my car. Just remember it's a hobby, so it doesn't matter how much you spend as long as your happy
Old Dec 8, 2005 | 03:27 AM
89B16Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2fanatic &raquo;</TD></TR><TR><TD CLASS="quote">this dude isnt ffuckin around haha... hope your de-ricing... but to each his own. looks like a badass setup bro... let us know what she runs </TD></TR></TABLE>
hah yeah i didnt do none of that to the car i bought it like that everythings comming off..
Old Dec 8, 2005 | 04:34 AM
Autoworks's Avatar
sweet build, glad to see the hatch in the hands of a good builder
Old Dec 8, 2005 | 04:44 AM
Pee Wee's Avatar
Default Re: (hellshock2182)
another fast *** car in va interesting decision going with the ys1. but i guess when you can rev to 10k it doesnt matter how short the gears are
Old Dec 8, 2005 | 05:05 AM
b20turboic's Avatar
Default Re: (EF8opey)
Id get a good LSD, that Type-ARR will **** out with that much power
but all in all good to see another 10 sec. ef hatch
Old Dec 8, 2005 | 07:01 AM
ghost_ryder35's Avatar
i just poked my self in the eye. Nice setup man!
Old Dec 8, 2005 | 07:50 AM
EJ1 wilcox's Avatar
Default Re: my 10sec b16 engine build for the hatch 56k take a nap... (ghost_ryder35)
Damn!
That's one serious build!
Good luck reaching your goals
Old Dec 8, 2005 | 08:07 AM
89B16Civic's Avatar
Default Re: (b20turboic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic &raquo;</TD></TR><TR><TD CLASS="quote">Id get a good LSD, that Type-ARR will **** out with that much power
but all in all good to see another 10 sec. ef hatch </TD></TR></TABLE>
yeah im going to, i got a good deal on this tranny so i picked it up...
Old Dec 8, 2005 | 08:12 AM
what rods (model not brand) are needed to run the ls crank in a b16a? what displacement increase does this have and whats the r/s equate to ?
