vtec hook up problems
Old Dec 7, 2005 | 07:05 PM
si0385.'s Avatar
Default vtec hook up problems
i just bought a crx with a d15b and they used the stock wireing harness... this includes ecu and distributor... but if i buy a vtec controler can i still run vtec or do i have to switch over to obd1
how can i tell the difference between an si and a dx wireing harness?
Old Dec 7, 2005 | 07:15 PM
C1CRX's Avatar
Traffic signal tech
Default Re: vtec hook up problems (jaydeum4lyfe)
yes with a vtec controller i believe you can still run vtec just make sure you wire up the vtec controller and a relay correctly and it should work. someone correct me if im worng.....and i dont know the diffrence between the harnesses
Old Dec 7, 2005 | 07:16 PM
AJxr's Avatar
Default Re: vtec hook up problems (lvcrx)
i have the same question with my mini set up
also how would i hook up the vtec oil pressure sensor?
Old Dec 7, 2005 | 07:20 PM
daidilus's Avatar
instead off all that jazz..get a fields SFC......run 0% gas below vtec engagment point and +10% on vtec
Old Dec 7, 2005 | 07:33 PM
AJxr's Avatar
Default Re: (daidilus)
thats what i have to engage my vtec, do i just run the vtec wires that come from the sfc directly to the solenoid?
Old Dec 7, 2005 | 07:59 PM
daidilus's Avatar
yeah...
http://asia.vtec.net/beystock/....html
Old Dec 8, 2005 | 03:41 AM
si0385.'s Avatar
where can i buy a SFC?
xvracing
May 1, 2004 01:49 PM
civickid03
Mar 25, 2004 11:00 AM
