b16 mounts?
Ok I searched and didnt find an answer so figured id ask. Will a b16a2 bold right in a eg or do i need hasport mounts? The EGSTK ones. They have so many mounts for eg's Im confused. Thanks Brent,
The Integra mounts someone mention above is incorrect. Only 2 of those mounts will work, unless you change a bracket.
The B16A2 will bolt right up into the EG (92-95) using the stock mounts. You will need to use the B16A2 shift linkage {non DelSol} and axles as well (not the ones from the EG). If you don't have those items coming with the swap, you will need to purchase them.
You can use HASport mounts instead of using stock mount for a stiffer mount so the motor will torque over less in the engine compartment. If you decided to go with the HASport mounts, the correct kit would indeed be the EGSTK kit which you found.
There are other mounts out there from HASport for the EG to mount all different series engines in the EG, and I can see where it can get confusing, but you did find the correct ones and the only ones that would be needed for your swap the EGSTK.
You will require a different AC bracket if you choose to retain AC, -well that it is maybe -guess it depends on where you are sourcing the engine from and what it is being pulled out of, if it is a true B16A2.
If you have any questions, feel free to contact us directly and we can try to help clear up the situation.
Powered by VTEC
18
Dec 22, 2007 06:14 AM
