parts list needed...timing belt, water pump changing
I hear it was smart to replace the tensioner also.
I bought a T-belt kit from prostreetonline. Thats whats included in theirs. Since you have to remove the valve cover, check that rubber gasket. If it looks bad, replace it. If its fine, leave it.
you should replace the timing belt, water pump, and the tensioner.. i just did mine a few months ago... really easy if u have an impact gun, if not the crank bolt is fun to get off
oh yea, and when removing the lower mount.. dont use the gun on it... mine tore to shreds. .it was only like $10 for a new one,.. but still..
good luck
oh yea, and when removing the lower mount.. dont use the gun on it... mine tore to shreds. .it was only like $10 for a new one,.. but still..good luck
timing belt, all of your outer belts, water pump, cam seal, crank seal, valve cover gasket set (should also include gromets and plug tube seals; you also want to remember grey RTV sealer on the corners of the vc gasket) thermostat (don't forget the o-ring). unless the tensioner is making noise you can reuse it. btw this is what you would get if you had it done at the dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 »</TD></TR><TR><TD CLASS="quote">timing belt, all of your outer belts, water pump, cam seal, crank seal, valve cover gasket set (should also include gromets and plug tube seals; you also want to remember grey RTV sealer on the corners of the vc gasket) thermostat (don't forget the o-ring). unless the tensioner is making noise you can reuse it. btw this is what you would get if you had it done at the dealership. </TD></TR></TABLE>
exactly what i needed...
TougeCoupe
Nov 19, 2009 03:56 AM
dELfONiK
Feb 21, 2006 06:37 AM
B18Redline
Nov 6, 2004 10:26 AM
Origin
Nov 15, 2003 09:33 PM
