whats a better HEad work on a b20?
Old Dec 7, 2005 | 02:02 PM
naSquad_ej8's Avatar
Default whats a better HEad work on a b20?
gsr... or a b16.. what u think? And which one wil last longer if the head work is done right?
Old Dec 7, 2005 | 02:05 PM
EJ1 94's Avatar
Default Re: whats a better HEad work on a b20? (naSquad_ej8)
B16
slikz714's Avatar
boost or n/a? i like the b16
Old Dec 7, 2005 | 03:22 PM
typeoneeg6's Avatar
Default Re: whats a better HEad work on a b20? (slikz714)
b16 or type r. gsr has smaller combustion chamber which will raise compression.
Old Dec 7, 2005 | 03:36 PM
StreetEG's Avatar
Default Re: whats a better HEad work on a b20? (typeoneeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeoneeg6 &raquo;</TD></TR><TR><TD CLASS="quote">b16 or type r. gsr has smaller combustion chamber which will raise compression.</TD></TR></TABLE>
Does that make it better or worse?
Isnt that desirable for an N/A application
Old Dec 7, 2005 | 04:56 PM
typeoneeg6's Avatar
Default Re: whats a better HEad work on a b20? (StreetEG)
it really depends on what you want to do with the car. any of those heads will work fine for a daily driver or occasional track car. the best thing you can do is consult an engine builder about what your goals are. they can help you decide what setup will meet your goals. if you want to go na then yes you want higher compression. but you can also achieve a higher compression by replacing internals, which if youre truly building the motor i would hope you would do anyway. if its gonna be a daily driver then you want something that is streetable and not going to drive you nuts. if boost is your game so be it. but if you want a street car than 30 psi is a bit much. just like a 13:1 and up cr/vtec is a little bit overkill.
Old Dec 7, 2005 | 05:10 PM
jin05's Avatar
b20 wit itr head. torque n hp
Old Dec 7, 2005 | 05:21 PM
Si Jeff's Avatar
B16 or ITR!
Old Dec 8, 2005 | 10:43 AM
DB1_559's Avatar
itr
Old Dec 8, 2005 | 12:33 PM
LSracing94's Avatar
Default Re: whats a better HEad work on a b20? (jdmboi86)
CTR
Old Dec 8, 2005 | 01:22 PM
Kidnkorner's Avatar
Default Re: whats a better HEad work on a b20? (LSracing94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">CTR</TD></TR></TABLE>
Same as a ITR.
Id go with the GSR head, the cumbustion chambers are squared off on the intake and exhaust side, this improves the quench. people who modify PR3 heads sometimes weld the cumbustion camber to replicate this benefit.
Old Dec 8, 2005 | 03:11 PM
hondaboy4life's Avatar
Default Re: whats a better HEad work on a b20? (Lynx Bus Type R)
well wasnt the type r head copied from the b16 head...?
Old Dec 8, 2005 | 03:12 PM
TheNasty0ne's Avatar
Cant beat PnP GSR head.
Old Dec 8, 2005 | 03:13 PM
Default Re: whats a better HEad work on a b20? (SkAnK_aSS_BRyAn)
ITR head = PnP B16 head with different cams, valves etc
CTR head = Pnp b16 with different cams, vavles etc
GSR is the best head due to its square combustion chambers = high compression
acurab20b
May 16, 2010 07:38 AM
SwappedTURBOegg
93
Oct 30, 2009 12:00 AM
93LsVx
Jan 4, 2009 05:26 PM
torqueMONSTER
Jul 28, 2005 05:06 PM
