Fed up with slipping skunk2 cam gears (bolt swap?)
Hey guys, I talked to Mike M from IPS racing and I asked him about if there was anything I can do with securing my skunk2 adjustable cam gears (non-pro version)
He said to get Toda gears
but he also said something about swapping the bolts on the skunk gears and theres something about it on h-t. I couldn't find anything on swapping the bolts on the skunk2 gears and I was wondering if u guys can shed some insight on this, thanks
ps my skunk2 cam gears have slipped on me twice with proper torque and sequencing
hmm red loctite? i know of regular loctite in liquid form. But I guess i'll look into red loctite. Where would i apply it?
just put a small drop on the threads. that **** will keep those bolts tight and they will not come loose on you anymore. hope that takes care of your problem. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbogsr »</TD></TR><TR><TD CLASS="quote">just put a small drop on the threads. that **** will keep those bolts tight and they will not come loose on you anymore. hope that takes care of your problem. good luck</TD></TR></TABLE>
thx
thx
yes he will, i have done it a few times on my car and i am sure he would rather have a pain in the *** getting them off then a slipping cam gear that could end up causing him to bend valves. i know from personal experience. it ****** blows.
just use a dab of it on each bolt thread and you will be fine.
