I already searched PLEASE HELP
Old Dec 7, 2005 | 12:50 PM
MPALUGHI's Avatar
Default I already searched PLEASE HELP
I bought an EF from my boy that has eibach's all around but he used stock struts. I have hasport mounts and it sits to low to the ground. The oil pan is like 4" from the ground and in the east coast it's like driving through a mine field with the roads out here. I was thinking about buying like KYB AGX struts to fix my problem. Is anyone running a similar setup that can give me some insight? It sucks being so low to the ground.
Old Dec 7, 2005 | 12:53 PM
Steve91's Avatar
Default Re: I already searched PLEASE HELP (MPALUGHI)
The shocks will have no effect on ride height. You need to change the springs. You should get some Ground Control coilovers so you can adjust the height to fit your road conditions. Upgrading the shocks is a great idea, just know that it will not effect ride height.
Old Dec 7, 2005 | 07:28 PM
jdmcars.com's Avatar
The shocks *could* be so far gone that the are making the springs sag and hold all the weight.
I assume they are probably the ProKits, and with that set up, I have used Bilsteins and have had good luck, and I have seen just by putting them on a certain worn out cars, that they can raise the car about .5" or so, which is a big difference.
BoboyRS
Jan 14, 2009 12:04 AM
jimmypol
Suspension & Brakes
Aug 15, 2007 06:26 PM
97BB6Type-SH
Jul 3, 2006 01:46 PM
MadWackOops
Nov 9, 2003 09:28 PM
djay86
Sep 8, 2002 04:20 PM
