dual valve springs on a d-series head?? (dohc zc)
Old Dec 7, 2005 | 11:39 AM
hatchinprogress's Avatar
Default dual valve springs on a d-series head?? (dohc zc)
i searched but there were no pics and not much info on dual valve springs for d-series heads, so i need to know is there a special way to install the springs? and can the springs be used with oem springs(if there in spec)....and also is there even room in a d-series head?(even though it's a dual cam) also my cams are delta's any info would help alot
Old Dec 7, 2005 | 11:58 AM
youtouchmytralala's Avatar
Default Re: dual valve springs on a d-series head?? (hatchinprogress)
Installing valuve springs in a DOHC Zc head is straight forward.
Old Dec 7, 2005 | 11:59 AM
Default Re: dual valve springs on a d-series head?? (youtouchmytralala)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youtouchmytralala &raquo;</TD></TR><TR><TD CLASS="quote">Installing valuve springs in a DOHC Zc head is straight forward. </TD></TR></TABLE> so they will fit ? and is it ok if i use the stock springs also? (with the aftermarket on the inside of the oem springs?)
Old Dec 7, 2005 | 03:52 PM
anyone???
Old Dec 7, 2005 | 03:53 PM
green91's Avatar
obviously if he says they are straightforward they will fit. not fitting would be an obstacle, and thus not be straightforward
Old Dec 7, 2005 | 04:08 PM
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">obviously if he says they are straightforward they will fit. not fitting would be an obstacle, and thus not be straightforward</TD></TR></TABLE> im just tryin to get a def. answer because a reputable member(on ht) says there is no room in a d-series head
Old Dec 7, 2005 | 05:45 PM
Autoworks's Avatar
Default Re: (hatchinprogress)
JG makes a dual spring that will fit
Old Dec 7, 2005 | 07:10 PM
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">JG makes a dual spring that will fit</TD></TR></TABLE> ok so i guess dual springs can fit in a d-series yo auto what happened to you?? you never got back to me about the parts i needed?????????????
liam821
Jun 5, 2003 06:10 PM
APEXI Si
Nov 28, 2002 07:42 PM
