bay area pickup- miller synchrowave 180SD W/ 150CuFT bottle picked up 1500$ !
ProFab Tri-Y Headers
- Revised Ground Clearance
- Stepped Header Design 1 3/4 to 1 7/8 to 2 inch to 2.5
- Merge collectors
- 16 Gauge mild steel
- Ceramic coated
- Ported headflange
- 2.5 Collector
- VERY GOOD RESULTS- Many all motor 200-240 WHP setups proven
- IN STOCK
-<FONT COLOR="blue"> 500$ SHIPPED </FONT>
SDR Twister header
-16 GA mild steel
-Ported headflange
-2.5 Street collector
-1 piece welded design
-Ceramic Coated
-Equal length 1 3/4 primary's
-Works with the stock crossmember
- IN STOCK
- <FONT COLOR="blue"> 590$ SHIPPED </FONT>
Modified by project dc2 at 11:27 AM 4/29/2006
Modified by project dc2 at 11:34 AM 4/29/2006
- Merge collectors
- Ceramic coated
- Ported headflange
- 2.5 Collector
- IN STOCK
SDR Twister header
-16 GA mild steel
-Ported headflange
-Ceramic Coated
- IN STOCK
<U>Innovative Mounts Products</U>
Finish: Black Wrinkle Powdercoat Inserts: Red - 60A Shore Hardness Standard, Upgrade to Race or Track for $10 Extra.
Description: Designed Perfect Fitment! Unlike other kits, no notching or trimming of the hood is required. Positions the motor with no axle bind. When installed, maximum front clearance is available for large headers or a turbo. Unique no-tear vibration minimizing.bushings. <U>CAD/CAM Designed</U>. Stress Analyized. Lifetime warranty. More Info Visit http://www.innovativemounts.com
88-91 Civic and CRX Conversion Mount Kit for B Series Engines with Cable Transmission $175shipped
88-91 Civic and CRX Conversion Mount Kit for B Series Engines with Hydraulic Transmission $350shipped
92-95 Civic Replacement Mount Kit for B and D Series Engines with Hydraulic Transmission and 2 Bolt Post Mount Setup $300 shipped
92-95 Civic Replacement Mount Kit for B and D Series with Hydraulic Transmission and 3 Bolt Post Mount Setup $300shipped
92-95 Civic A/T to M/T Conversion Mount for B and D Series Engines with Hydraulic Transmission $89.95shipped
96-00 Civic Drivers Side Replacement Mount for B and D Series Engines $119.95shipped
96-00 Civic Replacement Mount Kit for B and D Series Engines with Hydraulic Transmission $300shipped
96-00 Civic Conversion Mount Kit for H and F Series Engines $300shipped
90-91 Integra Replacement Mount Kit for B Series with Cable Transmission $300 shipped
90-93 Integra Replacement Front Mount for B Series with Cable Transmission(NEW) $115shipped
92-93 Integra RS/LS Replacement Mount Kit for B Series with Cable Transmission $300shipped
92-93 Integra GSR Replacement Mount Kit for B Series with Cable Transmission $300shipped
90-91 Integra Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
92-93 Integra RS/LS Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
92-93 Integra GSR Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
94-01 Integra Replacement Mount Kit for B and D Series with Hydraulic Transmission $300shipped
94-01 Integra A/T to M/T Conversion Mount for B and D Series Engines with Hydraulic Transmission (NEW) $115shipped
02-06 RSX Replacement Mount Kit for Hydraulic Transmission (NEW)
$290shipped
92-96 Prelude Replacement Mount Kit for H and F Series (NEW)
$280.00 shipped
<FONT COLOR="red"> Cross Members </FONT>
Civic CRX Front Crossmember $260 Shipped
Civic CRX Front Crossmember HIMOUNT $260 shipped
B/D Series Cable to Hydraulic Actuator (NEW) $180shipped
Crossmember Bushing and Caster Adjustment Set (NEW) $50 shipped
<U><FONT COLOR="blue">NEW INNOVATIVE BILLET SERIES !!!</FONT></U>
Item #: B10010
Cost: $175.99 SHIPPED - Driverside cage and mount
Finish: Unfinished Aluminum or Black Anodized.
Inserts: Red - 60A Shore Hardness Standard, Upgrade to Race or Track for $5 Extra.
Description: Available in Innovative's signature look of black finish or unfinished aluminum. <U>Billet Replacement </U>mount for 1996-2000 Honda Civic. Designed to fit all B and D series motors. An alternative to the mediocre oil filled factory mount. Urethane stiffness from soft for the street to solid for the track is available. CNC Machined from 6061 Aluminum. Unique no-tear vibration minimizing bushings. CAD/CAM Designed. Stress Analyized. Lifetime warranty. All hardware is included.
Item #: B19150
Cost: $249.99 SHIPPED
Description: Available in Innovative's signature look of black finish or unfinished aluminum. Billet Replacement mount for 1988-1991 Honda Civic or CRX. Designed to fit all B-Series motors (B16, B17, B18, B20) with cable transmission. Unlike other kits, no notching or trimming of the hood is required and even clears B20 engines. Positions the motor with no axle bind. When installed, maximum front clearance is available for large headers or a turbo. CNC Machined from 6061 Aluminum. Unique no-tear vibration minimizing.bushings. CAD/CAM Designed. Stress Analyized. Lifetime warranty.
Modified by project dc2 at 2:01 AM 4/20/2006
Modified by project dc2 at 2:03 AM 4/20/2006
$290shipped
$280.00 shipped
Item #: B10010
Item #: B19150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">You get the new 200?
I think thats going to start a new bandwagon
my pops bailed on me. otherwise i would've kept my 180. my new shop i wanted a smaller welder that could chill in the corner/runner cart.
</TD></TR></TABLE>my pops bailed on me. otherwise i would've kept my 180. my new shop i wanted a smaller welder that could chill in the corner/runner cart.
