What are you using to cut sheet metal ?
Found these, which one would work the best ? Any other options ?
http://www.harborfreight.com/c...46061
http://www.harborfreight.com/c...36567
http://www.harborfreight.com/c...36568
Modified by 90blackcrx at 12:53 PM 12/7/2005
I use 3 different size shears.. Biggest Cut up to 14 ga. Fits 8" wide sheet.
Also have a electric nibbler for smaller cuts.
Tinsnips work as well as a die grinder for fitting!
I have an air nibbler, air shear, hobart plasma cutter and a crapload of cutoff wheels. I like the plasma cutter best with the air shears coming in a close second. The nibbler is a bitch because the little nibs it cuts out get in your shoes and stuff and cut the hell out of you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge »</TD></TR><TR><TD CLASS="quote">I have an air nibbler, air shear, hobart plasma cutter and a crapload of cutoff wheels. I like the plasma cutter best with the air shears coming in a close second. The nibbler is a bitch because the little nibs it cuts out get in your shoes and stuff and cut the hell out of you.</TD></TR></TABLE>
Thanks
Thanks
