cam gears and pullies
Old Dec 6, 2005 | 05:28 PM
mountaindewguy's Avatar
Default cam gears and pullies
ok just a couple questions...
first, aem pullies....any yays or nays about the alternator/PS pullies?
cam gears:
if im looking at getting a stage 1 comp cam (zex), do i need an adjustable cam gear? or will the stock one be OK.. .cause it says made to use with stock stuff..
and does it need to be dyno tuned if i do need a cam? i was told in a recent post that if you have an adjustable cam that it needs to be dyno tuned... i know alot of people with them and theres no dyno around...
is there no way to correct the timing without a dyno?
sorry, new to the cam/cam gears subject..
thanks all
Old Dec 6, 2005 | 05:32 PM
platinum00's Avatar
Default Re: cam gears and pullies (mountaindewguy)
you dont need a cam gear, and the pullies are OK. you lights will dim at idle with the alternator one.
i have the alternator and power sterring if you want to buy them from me. in RED. 50 bucks plus your stock alternator pully
platinum.
Old Dec 6, 2005 | 08:07 PM
any more unput?
Old Dec 6, 2005 | 09:18 PM
cambopheonix56's Avatar
if you put on an adjustable cam gear, how do you know what to change the setting to? The only way to know is to hit up a dyno, to see what the most effect settings are.
Old Dec 6, 2005 | 09:21 PM
Turbo_y8's Avatar
Default Re: cam gears and pullies (cambopheonix56)
timing light... or set it to zero or street tune it, lots away around a dyno
Old Dec 6, 2005 | 09:24 PM
Default Re: cam gears and pullies (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">timing light... or set it to zero or street tune it, lots away around a dyno</TD></TR></TABLE>
Well I just think the best way is to take a trip to a dyno to get the optimal setting.
Old Dec 6, 2005 | 09:25 PM
Turbo_y8's Avatar
well does it same you must run a advanced/retarded timing, if not stock timing, simple as that
Old Dec 6, 2005 | 09:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">well does it same you must run a advanced/retarded timing, if not stock timing, simple as that</TD></TR></TABLE>
Well a dyno will show how much power your putting out, thus you can adjust it accordingly.
Old Dec 6, 2005 | 10:09 PM
well, there isn't a dyno in iowa, at least to my knowledge...
so if i were to get one i guess i would set it at zero, which would be stock, right?
is there markings on the gear teeth to show zero?
Old Dec 6, 2005 | 10:11 PM
**** i think i'll just get the stage 1 cam and leave the gear alone... seems to big of a hassle considering i dont even need it...
any more input on the pulleys?
thanks
Old Dec 7, 2005 | 09:57 AM
platinum00's Avatar
yea, but mine and give me your stock stuff.
platinum
Old Dec 7, 2005 | 10:43 AM
There is a dyno in minnesota, search and you can find it. I think its called mineesota sport compact. But you can gain a few ponies with an adjustable camgear.
Old Dec 7, 2005 | 10:59 AM
platinum00's Avatar
if it's a single cam it really just moves the powerband around a bit
platinum.
Old Dec 7, 2005 | 12:17 PM
Default Re: cam gears and pullies (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">if it's a single cam it really just moves the powerband around a bit
platinum.
Thats true, yea i wouldnt wastemy money then. You can spend the money elsewere, and benefit more.
Hyoriu
Nov 27, 2008 02:56 PM
ej1252
Nov 10, 2007 04:26 PM
f22abuilder
Feb 16, 2006 06:10 AM
gdout90accord
Mar 29, 2004 12:07 PM
EGinNY
Oct 2, 2003 11:23 PM
