Suspension & Brakes Theory, alignment, spring rates....
stiff suspension
Old Dec 6, 2005 | 02:15 PM
egb18c5's Avatar
Default stiff suspension
i was lookin at a couple of photo's and i notice when some people jacks up their car, the wheel stays tucked in the fender. what makes it stay like that?? sorry i have no pics
Old Dec 6, 2005 | 02:35 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stiff suspension (egb18c5)
Chances are that they have the jack underneath the lower control arm. That will compress the suspension but keeps the car in the air.
Always keep jackstands on the proper body points for safety. Then you can put your jack under one of the LCAs & lift it until the car just barely rises of the nearest jackstand. This is one of the best ways to look for problems in your suspension (bad balljoints & bushings, etc...).
Old Dec 6, 2005 | 04:25 PM
JDMmaster's Avatar
The stiffer your suspension (most likely also shorter), the less the wheel will drop when the car is lifted.
Old Dec 6, 2005 | 04:32 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stiff suspension (JDMmaster)
Droop has nothing to do with stiffness. It only has to do with shock travel.
He mentioned that the tires were "tucked". No susupension will leave your tires "tucked" in droop. How the hell would you get the damn wheels off?!?!
Old Dec 7, 2005 | 06:48 AM
egb18c5's Avatar
Default Re: stiff suspension (94eg!)
lookin again, they didn't have the jack under the lower control arm. matter fact on some cars, when they go up in the driveways, there on 3 wheels. i thought the tire usually drops not stay up. still tryin to find out what causes this.
Old Dec 7, 2005 | 07:17 AM
577HondaPrelude's Avatar
if it was only jacked up on 1 side then the anti-sway bars will not let the jacked up side wheels droop very much.
Old Dec 7, 2005 | 09:00 AM
JDMmaster's Avatar
good question, but i was not trying to explain why the wheels were still tucked. The sway bar may have something to do with it, but you can't say that the stiffness of the spring has nothing to do with how much the wheel will droop when the car is off the ground. The stiffer the spring the less the car will compress it, therfore the less it will droop when the car if of the ground. shorter shock travel usually comes with a stiff spring cause we dont want our cars to be monster trucks now do we???
Old Dec 7, 2005 | 09:34 AM
Circuit Star-29's Avatar
OMG
Old Dec 7, 2005 | 09:53 AM
Kendall's Avatar
A lot of it depends on if the setup is height adjustable at only the spring, or at the shock body as well. A setup lowered entirely at the shock body will not droop as much as an identical setup lowered at the spring. Plus you have certain setups like Ohlins PCV setups that completely seal the valves shut when set to full stiff and don't droop at all.
Old Dec 7, 2005 | 10:02 AM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Droop has nothing to do with stiffness. It only has to do with shock travel.
Old Dec 7, 2005 | 10:59 AM
TunerN00b's Avatar
Default Re: stiff suspension (577HondaPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">if it was only jacked up on 1 side then the anti-sway bars will not let the jacked up side wheels droop very much.</TD></TR></TABLE>
I think the answer is right here.
Old Dec 7, 2005 | 11:01 AM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMmaster &raquo;</TD></TR><TR><TD CLASS="quote">good question, but i was not trying to explain why the wheels were still tucked. The sway bar may have something to do with it, but you can't say that the stiffness of the spring has nothing to do with how much the wheel will droop when the car is off the ground. The stiffer the spring the less the car will compress it, therfore the less it will droop when the car if of the ground. shorter shock travel usually comes with a stiff spring cause we dont want our cars to be monster trucks now do we???</TD></TR></TABLE>
wait are you serious? or is this some sort of lame sarcasim thing, missing the smilely faces and tounge sticking out....?????????????
Old Dec 7, 2005 | 11:25 AM
Default Re: stiff suspension (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I think the answer is right here. </TD></TR></TABLE>
I think you're wrong.
Old Dec 7, 2005 | 11:58 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stiff suspension (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">wait are you serious? or is this some sort of lame sarcasim thing, missing the smilely faces and tounge sticking out....?????????????</TD></TR></TABLE>
LOL!
Old Dec 7, 2005 | 01:48 PM
egb18c5's Avatar
i think this is the most reasonable answer i heard
Old Dec 7, 2005 | 02:19 PM
94eg!'s Avatar
#1 Super Guy
Loved
Why don't you just link the picture in question. This is just a difficult debate without actually looking at whats going on...
Old Dec 8, 2005 | 02:34 AM
Mr.E.G.'s Avatar
if you are referring to race cars and the like they will have considerably less suspension travel than a street car will. for example (an extreme example) when an f1 car is jacked up the wheels dont look like they are going anywhere. they only travel about 1 inch.
a lot of street car based race cars look the same as the street car equivalent but thier suspension is completley different.
you have to consider that street cars need more shock travel because of the roda irregularities that they experience but a race car wont be hitting may bumps/ comfort is not an issue, so they have very little suspension travel.
Old Dec 8, 2005 | 07:59 AM
Dave421's Avatar
Wow, that's just..... I'm baffled.
You seem to understand that the spring will affect compression but when the weight is off the spring, what is it that you think that holds the spring in? If the spring were actually attached to the body and then the lca rather than merely sitting between them, then you'd be correct. Unfortunately, a spring does not in any way limit droop. It's purely a function of shock travel (and/or sway bar if both tires are not off the ground).
Old Dec 8, 2005 | 09:05 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stiff suspension (Dave421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">if you are referring to race cars and the like they will have considerably less blah blah blah...</TD></TR></TABLE>
The problem we have here is that the original poster is refering to a honda who's wheels remained "tucked". We have to see a picture to know whats going on because no wheel, on any race/street car, would remain tucked in a fender at full droop (no wheelie removie)...
Old Dec 8, 2005 | 09:09 AM
Tyson's Avatar
using extended top hats will "tuck" the tire. tuck probably isnt the right word to describe it. i think youre taking it way too literally. he just means not fully dropped like normal. im sure theres still some wheel travel, but the overall travel is significantly limited with stuff like extended top hats.
and some "racecars" do prefer to have droop limited.
Old Dec 8, 2005 | 10:18 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stiff suspension (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote"> i think youre taking it way too literally.</TD></TR></TABLE>
Your probably right, but without this guys giving us some examples we'll never know...
Old Dec 8, 2005 | 10:27 AM
bad-monkey's Avatar
yo i've heard of these super JDM UCA bushings that have so much stiffness they act like a torsional spring and suck up the suspension into the assembly, y0! combine that with my uber light LCA's and Volks and i can get my tire to tuck while doing wheelies over drawbridges, dawg!
o.g. poster: it could be a function of droop limiting, the sway bar idea sounds right too.
Old Dec 8, 2005 | 12:15 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (bad-monkey)
LOL!
Old Dec 8, 2005 | 12:27 PM
Tyson's Avatar
Default Re: (94eg!)
ive got a feeling that the original question was inspired by something like this, which you can do with omnipowers because of the short stroke of the shock.
as they say, "3 wheelin' y0!"
Old Dec 8, 2005 | 05:17 PM
KOALA YUMMIES's Avatar
Default Re: (Tyson)
Lol 90% of the people in the A/C forum and take these stupid pics dont even know what a good suspension is, let alone track their cars.
