Fixing AEM CAI Rub??
Old Mar 14, 2002 | 04:19 PM
GSRacer2102's Avatar
Default Fixing AEM CAI Rub??
My AEM CAI was rubbing and i just fixed it or at least I think I did. It had already started burning a little hole through the rubber on the hose. How did u all fix it? I got some foam like the one that comes on the bike handles. What kind of things did you all use to cover the air con hose?
Old Mar 15, 2002 | 03:06 AM
5-SpeedFreak's Avatar
New User
Default Re: Fixing AEM CAI Rub?? (GSRacer2102)
Foam? Uhh, remember that underhood temps are very high!
If you look under the hood of your car, you'll see black automotive hose. Try to find that kinda material in your garage (where I found mine) or at a junkyard/auto shop. all you need is about 2" worth. Not much.
Cut it lengthwise, wrap it around the AC lines, affix it with zipties. You'll be good to go.
Old Mar 15, 2002 | 04:08 AM
Ohlias's Avatar
Default Re: Fixing AEM CAI Rub?? (fuzznuts)
From what I've heard, there is a lot of pressure in them there AC lines (When in use I guess). I'm not so sure you want to go bending them too much...be careful.
Ohlias
Sep 5, 2002 03:03 AM
IntegraGSR23
Mar 6, 2002 08:23 AM
SpoonFed
Jan 29, 2002 06:10 AM
friedsqrl
Jan 25, 2002 12:40 PM
StinkyTofu
Sep 14, 2001 11:43 PM
