Clutch and flywheel brand?
Old Dec 6, 2005 | 11:04 AM
FOMULA91's Avatar
Default Clutch and flywheel brand?
What type of clutch and flywheel does everybody use? I’m asking this because I was thinking to change my clutch kit and the flywheel too. I know ACT and Toda is one of the best brands but my budget is kinda low, so I was planning to purchase some EXEDY clutch and the racing flywheel. Anybody use EXWDY before? Are they or . Just wanted to know if they are reliable or not.
Also where do everybody purchase their clutch? Some local performance shop or online?
Old Dec 6, 2005 | 11:08 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Clutch and flywheel brand? (FOMULA91)
I've run Exdey clutchmasters and ACT. Ram *on t-5s* I liked them all with fondness for clutchmasters mated with the 8.8lb fly
Old Dec 6, 2005 | 11:11 AM
SSJSubgeta's Avatar
I personally went with an Excedy Stage 1 clutch kit, very reliable for daily and ahem, racing, ahem situations. I installed it in my HF with a D15 Vtec and revs nice, clutch engages beautifully. As for the price I looked on the bay and for $120 bucks shipped to your door not bad at all.
**This is my own experience with the Excedy Stage 1 clutch kit, opinions will vary between the individual, but from me it gets +1
Good luck
Old Dec 6, 2005 | 12:29 PM
FOMULA91's Avatar
Default Re: Clutch and flywheel brand? (SSJSubgeta)
Cool, thanks for the info guys. I also have an D15B VTEC in my 89 HF so, it should work fine.
Old Dec 6, 2005 | 12:51 PM
Bjorn20's Avatar
not to steal this thread... but um, are u supposed have to let off the clutch like 6 inches before it starts engaging? cuz my friends amigo, i let off the clutch like a milimiter and it engaged, but the pedal istelf would only move like an inch total, mine moves like almost a foot total, with a better clutch does it engauge faster?
Old Dec 6, 2005 | 03:29 PM
Rukusmasta2's Avatar
Default Re: (Bjorn20)
f1 racing Stg 3 clutch and a 7.5lb fidanza flywheel
Old Dec 6, 2005 | 03:30 PM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">not to steal this thread... but um, are u supposed have to let off the clutch like 6 inches before it starts engaging? cuz my friends amigo, i let off the clutch like a milimiter and it engaged, but the pedal istelf would only move like an inch total, mine moves like almost a foot total, with a better clutch does it engauge faster?</TD></TR></TABLE>
You could adjust your clutch cable to engage where you want.
Old Dec 6, 2005 | 05:18 PM
migizzel's Avatar
How about when your clutch pedal gets harder is this a sing of needing to replace it
and by the way i have stock moving up to stage 1 excedy clutch kit next pay check
Old Dec 6, 2005 | 05:23 PM
SVOboy's Avatar
Adjust your cable, I'll prolly set mine to disengage pretty quickly.
And PS: I'm buying an Exedy clutch, stock flywheel in the mail for my manual swap.
Old Dec 6, 2005 | 08:02 PM
FOMULA91's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">How about when your clutch pedal gets harder is this a sing of needing to replace it
and by the way i have stock moving up to stage 1 excedy clutch kit next pay check</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Adjust your cable, I'll prolly set mine to disengage pretty quickly.
And PS: I'm buying an Exedy clutch, stock flywheel in the mail for my manual swap.</TD></TR></TABLE>
Cool guys, let me know how you feel when you install it.
I'm wondering if I should go Stock flywheel and OEM EXEDY clutch kit or EXEDY Stage 1 Clutch kit with my OEM flewheel.
BTW what does the flywheel do if its lighter?
Old Dec 6, 2005 | 08:03 PM
FOMULA91's Avatar
Default Re: (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">f1 racing Stg 3 clutch and a 7.5lb fidanza flywheel</TD></TR></TABLE>
Are F1 Racing clutch any good? I know its cheap as hell but I'm a little worry about cheap products.
Old Dec 7, 2005 | 01:32 PM
Default Re: (FOMULA91)
i dont know ill tell u once its running motor is being rebuilt righ tnow
Old Dec 7, 2005 | 01:51 PM
90sedan's Avatar
I just put in a new OEM clutch.
Got it for free from honda.
Old Dec 7, 2005 | 04:09 PM
SVOboy's Avatar
Lighter flywheel = less mass the engine has to move, and since it's spinning, it's really good, cuz spinning an extra 10 is harder than dragging it.
J337_UNIT
Jul 25, 2003 10:03 PM
Mark
Jun 4, 2003 03:35 PM
redlineh22a
Feb 20, 2003 08:46 PM
ITR 0206
Jul 19, 2001 09:36 AM
