ITR clutch on GSR?
Old Mar 14, 2002 | 03:41 PM
whiteGSR's Avatar
Default ITR clutch on GSR?
anyone have this setup on their gsr? comments? feedback?
i have a i/h/e gsr and need a clutch real soon
the act street is about $100 US more than a stock ITR w/ new bearings, seals, etc...
i'll also be installing a ITR flywheel
should i save the 100 and just go OEM ITR? i don't plan on doing any major mods to my car, due to the new zero-tolercance performance mod here shared by some popo's (heck, i even have an stock ITR exhaust now)
or does anyone recommend the centerforce, exedy, spoon, clutchmasters, etc? keep in mind i'm on a budget
any comments/help will be GREATLY appreciated
oh yeah, i plan on taking to the drag strip a few times, and start auto-x'ing once i can afford to change tires every season...
[Modified by whiteGSR, 4:44 PM 3/14/2002]
[Modified by whiteGSR, 4:47 PM 3/14/2002]
Old Mar 14, 2002 | 04:08 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: ITR clutch on GSR? (whiteGSR)
i have the ITR clutch in my GS-R along with the ITR flywheel. if money is there and you have the time id get an aftermarket clutch. if you want pedal feel close to stock get the ITR or an ACT street disc. else go with a stage 2 or 3 clutch for more grip and better power handling.
you'll notice the difference in the ITR flywheel the most.
Old Mar 14, 2002 | 04:13 PM
Mr. Softee's Avatar
Default Re: ITR clutch on GSR? (FuknGSR)
i got my itr clutch w/ TOB for 200$. Its great, could be a little more heavy duty, but I love the stock feel.
Old Mar 14, 2002 | 08:01 PM
TomO's Avatar
Default Re: ITR clutch on GSR? (94goldjungsr)
I checked into the dealer on this subject as I was wondering the differences in the ITR and GSR clutch setup...the part numbers for the actual friction plate of the ITR and GSR are the same, along with the TOB. The only thing that had a different number between the two was the pressure plate. So maybe just getting an ITR pressure plate and an aftermarket friction disc woudl be a good way to go? I still might fo with the whole ITR setup, since I like to stick OEM stuff and I get a dealer discount now.
Tom O.
P.S.- how much more pressure is required on the clutch pedal with the ITR setup? TIA
Old Mar 14, 2002 | 08:07 PM
whiteGSR's Avatar
Default Re: ITR clutch on GSR? (SonicGSR98)
r u sure they're the same? (the friction plate, i mean). the dealer said u can't mix n match the itr/gsr clutch components w/ each other, so u have to go one or the other..
oh yeah, that plus the gsr plate/disc costs more than the itr plate/disc
[Modified by whiteGSR, 9:07 PM 3/14/2002]
Old Mar 14, 2002 | 08:43 PM
TomO's Avatar
i'm just going by what the dealer parts guy said, that the friction plates show the same number between a 98GSR and 98ITR but the pressure plates had different numbers. I'm just going to buy the whole ITR clutch package anyway since it's cheaper than the GSR one and a little better.
Tom O
Old Mar 15, 2002 | 12:59 AM
2fknlo's Avatar
Default Re: ITR clutch on GSR? (anger)
Im thinking of going OEM myself
Anyone know how much more pressure is on the ITR pressure plate than GSR?
Also whats the difference in the ITR flywheel, lighter?
What material is the disc made of?
[Modified by 2fknlo, 10:01 AM 3/15/2002]
Old Mar 17, 2002 | 05:36 AM
IN VTEC's Avatar
Default Re: ITR clutch on GSR? (2fknlo)
The difference in pedal pressure is negligible. I've driven my car and my friend's ITR back-to-back, I could just hop right in and drive it like I was driving my car with zero learning curve.
The ITR flywheel wieghs 15lbs, and the GS-R flywheel weighs closer to 18-19lbs.
The clutch discs are probably made of organic material for easy engagement.
Old Mar 17, 2002 | 05:38 AM
IN VTEC's Avatar
No
No
Yes, it's compatible.
No, splines should be the same.
Old Mar 17, 2002 | 07:39 AM
Erik_Pb_Foot's Avatar
New User
Default Re: ITR clutch on GSR? (IN VTEC)
I had an ITR clutch and 10 lb flywheel in my LS tranny. worked great. how much is the OEM setup? You can get the Exedy for about $250.
ruffrhyder
Transmission & Drivetrain
Aug 17, 2008 07:49 PM
spintboy
Dec 19, 2007 02:48 PM
bocian
Mar 31, 2002 07:50 PM
Integra_B18B
Jan 1, 2002 07:26 PM
1fastGSR
Dec 3, 2001 05:57 PM
