b16a stroker???
Old Dec 6, 2005 | 05:08 AM
psegs80's Avatar
Default b16a stroker???
I was thinking of getting a jdm b16a2 and putting in CTR cams and a stroker kit!
Toda 81.5mm bore with 87.2 stroke = 11.0:1 comp, 1.54 RS ratio and 1797cc
or
Crower 84mm bore with 84.5 stroke = 11.0:1 comp 1.59 RS ratio and 1.87L
Has anyone on here done something similar?
Old Dec 6, 2005 | 06:04 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: b16a stroker??? (psegs80)
The crank on a Honda is prolly 1 of the best parts in the engine. Replace it with a GS-R or Type-R crank and Bore it out. Buy new Rods and Pistons tho. If you dont wanna sleeve the block you could go like this 82mm x 87.2mm = 11.6:1 ??? That should be close to a 1.8
Old Dec 6, 2005 | 06:40 AM
psegs80's Avatar
Default Re: b16a stroker??? (You_Get_Vapors)
my friend races in the Hankook touring in Quebec Canada and he has a b16b knifed crank and b16b rods! I was told that the b16a2 bottom end wont take those parts???
Old Dec 6, 2005 | 06:43 AM
You_Get_Vapors
Guest
Posts: n/a
What parts?
Old Dec 6, 2005 | 07:50 AM
psegs80's Avatar
The crank and the rods frm a ctr!!! I got a michiniest to knife edge the crank!!!
Old Dec 6, 2005 | 07:54 AM
You_Get_Vapors
Guest
Posts: n/a
I think you would be able to do that with aftermarket pistons. Not positive tho.
Old Dec 6, 2005 | 08:06 AM
psegs80's Avatar
I can get jdm ctr psitons no prob...I just was told the b16a2 block was shorter and wouldn't work ???
Old Dec 6, 2005 | 08:15 AM
ZacCarter's Avatar
The b16b is a whole different animal from the b16a, It is a destroked 1.8, It has a whole different crank than any of the bseries motors have, It is possible to use this crank but aftermarket rods will need to be used. B16B internals can not go in the b16a, the pistons will come out of the bore.
Old Dec 6, 2005 | 08:27 AM
SonicRacing's Avatar
ctr pistons are shitty... you might as well go for some after market pistons...
Old Dec 6, 2005 | 08:38 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (ZacCarter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">The b16b is a whole different animal from the b16a, It is a destroked 1.8, It has a whole different crank than any of the bseries motors have, It is possible to use this crank but aftermarket rods will need to be used. B16B internals can not go in the b16a, the pistons will come out of the bore.</TD></TR></TABLE>
The bore and stroke are the same. The piston to deck height is different. Therefore you would need a piston to compensate for it.
Old Dec 6, 2005 | 08:45 AM
Kendall's Avatar
Arias manufactures a reduced compression height piston that will allow this to work, but you need to rebush the rods to accept a .702 wrist pin. Crower can rebush them for you.
The B16B uses a P72 block just like the ITR and GSR motors. The B16A uses a PR3 block with a considerably shorter deck height. The Toda stroker kit is basically just an ITR rotating assembly with some Toda parts in the mix.
Old Dec 6, 2005 | 08:49 AM
ZacCarter's Avatar
Default Re: (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">The bore and stroke are the same. The piston to deck height is different. Therefore you would need a piston to compensate for it.</TD></TR></TABLE>
Are you sure about the stroke I know the bore is still 81mm but i think the stroke is different.
Old Dec 6, 2005 | 08:50 AM
You_Get_Vapors
Guest
Posts: n/a
Yes im sure.
Old Dec 6, 2005 | 08:53 AM
ZacCarter's Avatar
Yea i just searched it 77.4 mm, But the type r is fully counterbalenced and polished.
Old Dec 6, 2005 | 08:56 AM
You_Get_Vapors
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The B16B uses a P72 block just like the ITR and GSR motors.</TD></TR></TABLE>
Its like a 1.8 block with a B16 crank. Different pistons. Rods? Compression is bumped up to 10.8 and has a more agressive cam. Revs like a B16.
Old Dec 6, 2005 | 08:57 AM
You_Get_Vapors
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">Yea i just searched it 77.4 mm, But the type r is fully counterbalenced and polished.</TD></TR></TABLE>
And bigger: 87.2mm &gt; 77.4mm
Old Dec 6, 2005 | 09:05 AM
ZacCarter's Avatar
The rods are the what is unique about the b16b. I got that confused with the crank.
Old Dec 6, 2005 | 07:56 PM
psegs80's Avatar
Now if I was to leave the b16a2 bottom end alone, is it possible to get near 200whp
Head work?
Throttle body?
Inatke manifold?
Cams?
Injectors?
valvetrain?
Headers 4-2-1 vs 4-1? collector size?
Cat or test pipe?
Cat back size?
I have had bad experience with bottom end work on a b18b and I'm not sure I want to down there again!!!
Old Dec 7, 2005 | 03:40 AM
ZacCarter's Avatar
yes it is possible, theres a guy in the all motor forum with a red eg hatch that broke 200, omni man did it as well.
Old Dec 7, 2005 | 09:49 AM
psegs80's Avatar
bolt ons or head work???
Old Dec 7, 2005 | 09:52 AM
ZacCarter's Avatar
rods pistons head work,cams, there is no way you'll even break 160 with bolt ons.
Old Dec 7, 2005 | 10:17 AM
JdmB16Eg6's Avatar
65.115.123.226
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of getting a jdm b16a2 </TD></TR></TABLE>
there is no such thing as a Jdm B16a2, b16a2 is the 2nd gen b16's that are from the 99-00 Si's. your thinking of b16a. sorry but that was bothering me
Old Dec 7, 2005 | 01:46 PM
psegs80's Avatar
Default Re: b16a stroker??? (JdmB16Eg6)
I don't want to touch pistons and rods but cams, vallvtraine 5 angle valve job, port and polish, bored throttle body that kind of stuff!!!
Old Dec 7, 2005 | 05:19 PM
ZacCarter's Avatar
with decent head work and itbs and nice header you can achiveve near 170, 180 maybe.
Old Dec 7, 2005 | 05:49 PM
psegs80's Avatar
I was thinking bored TB to 64mm, ported intake manifold, port n polish, 5 angle valve job, CTR cams with ITR valve springs, Aem cold air, DC sport jdm 4-1 heades with 2 1/2" collector, custom 2 1/2: cat back and fidanza flywheel and act stage one clutch set up???
