B16B NA dyno numbers,think i can make more?
Old Dec 5, 2005 | 11:58 PM
Takashi1978's Avatar
Default B16B NA dyno numbers,think i can make more?
Was recently tuned using a Apex'i Power FC
Stock B16B
Mugen Thin Head gasket
Mugen Intake
Mugen EK9 Twinloop
Feel's 4-2-1
All else stock.
I was suprise to be making power up to 8600rpm with stock CTR cams.
Old Dec 6, 2005 | 01:07 AM
Mohsin's Avatar
damn thats some gd TQ numbers, nice!
Old Dec 6, 2005 | 06:35 AM
RudeBwaiSi's Avatar
I am seeing the torque graph, but not believing it.
Old Dec 6, 2005 | 06:43 AM
jdm123's Avatar
Default Re: (RudeBwaiSi)
what kind of dyno is that on. those torque numbers seem way to high.
Old Dec 6, 2005 | 06:45 AM
D-Rob's Avatar
Default Re: (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of dyno is that on. those torque numbers seem way to high.</TD></TR></TABLE>
Those torque numbers are in Newton-meters, guys...
And those numbers look about right.
Old Dec 6, 2005 | 06:46 AM
DanishR's Avatar
The torque scale is Nm (Newton*meter).
Old Dec 6, 2005 | 06:47 AM
jdm123's Avatar
Default Re: (D-Rob)
newton meters? never heard of em.
HatchAttack242's Avatar
If you would more carefully read the chart, you will see that the torque is rated in Nm.
143Nm is around 105 ft-lbs
Old Dec 6, 2005 | 06:59 AM
Default Re: (HatchAttack242)
The funny thing was i tried 3 runs with the stock CTR ECU and although it was 32c weather outside my runs were
dyno run 1- 145hp
dyno run 2- 147hp
dyno run 3- 152hp
Thats when we swap out the stock ecu with the Power FC and loaded a base map.
All in all the car ran much smoother but the most suprising part is when in 5th gear the car is so much more willing to go.
And not to mention fuel economy inproved and i could get another 40-60km more out of the tank of gas.
Old Dec 6, 2005 | 07:07 AM
RudeBwaiSi's Avatar
You had me there.
AlienKrOZ
Jul 16, 2007 09:53 AM
14
Nov 7, 2006 05:54 PM
kay_animation
Jul 8, 2005 07:42 AM
Edward
May 29, 2005 04:38 AM
jji106
Apr 28, 2004 09:08 PM
