Built GSR/PR3 Head what else should i change???
Hey i just bought all these parts
skunk 2 modded intake
64mm bored throttle body
rc 440cc injectors
Crower stg2 cams
lightened rocker arms
fully ported pr3 head extensive chamber work opened to 84mm
crower stainless 1mm over intake valves
ferrea stainless .5mm over exhaust valves
crower springs and ti retainers
new valve seats and guides
arp head studs
b18c block has been t-sleeved with AEBS sleeves
re bored main caps for use of arp main studs
crank has been lightened 2lbs
rotating assebly has been fully balanced to within .01g
eagle rods
endyn 84.5mm hi compression pistons with flycut intake pockets
custom made chromoly flywheel 8lbs
act stage 3 clutch
s80 typr r transmission with lsd
right now the engine is not put together! last time it dyno'd was 220whp/158trq
i m wondering what else i should change?? to help raise this but still be street able
also i want it to be not too bad on gas, daily driven...
right now im thinkin of changing cams, to possilby a BC Spec3
any other help???
rc 440cc injectors
Crower stg2 cams
arp head studs
eagle rods
act stage 3 clutch
any other help???
ricearoni56
Nov 9, 2004 09:31 PM
