front LCA question..
Old Dec 5, 2005 | 07:07 PM
integra95gsr's Avatar
Default front LCA question..
when i was putting the nuts back onto the stud for the front LCA, the stud would just pin and then nut wouldnt go on. how do u get the nut on all the way?
Old Dec 5, 2005 | 07:27 PM
HiProfile's Avatar
Default Re: front LCA question.. (integra95gsr)
Wow, what crazy suspension do you have? Never heard of any civic with a STUD in the front.
I'm guessing you mean the long radius arm that mounts to the front crossmember? If so, you need to toss the cast LCA up there, slide the chassis bolt in, and put 1 bolt in to secure the radius arm to the lca. MUCH easier than trying to use any sort of wrench to hold that bar.
Modified by HiProfile at 11:20 PM 12/5/2005
Old Dec 5, 2005 | 07:31 PM
CRXb18Turbo's Avatar
Default Re: front LCA question.. (HiProfile)
You talking about the lower ball joint?
you put the nut in and then the pin...
Old Dec 5, 2005 | 07:34 PM
Default Re: front LCA question.. (CRXb18Turbo)
woops, yes the lower ball joint. ok so the "stud" or w/e that u thread the nut onto, it spins when i try to tighten the nut, so therefore it wont tighten!
Old Dec 5, 2005 | 07:38 PM
crxfornow's Avatar
ive had about five lower ball joints do that i usualy just go to napa or somewhere and just buy a new lower ball joint its the easiest way to go plus you know you wont have to replace it again for a while
Old Dec 5, 2005 | 07:39 PM
youtouchmytralala's Avatar
get a impact gun on it and spin the mo expletive out of it, eventually it will tighten down. or beat the knuckle into the lower control arm a bit and try tightening it. aint no pussies over here partner.
Old Dec 5, 2005 | 07:41 PM
lol...ill see what i can do..
Old Dec 5, 2005 | 10:54 PM
Tyson's Avatar
Default Re: (integra95gsr)
yeah, using an impact gun helps a lot.
so does a new castle nut.
or rethreading your old castle nut.
did i mention your problem is most likely the castle nut? they get stretched and dinged when you use them and take them out, which causes the friction that grips the balljoint enough to spin it. or it could be you knackered the balljoint threads itself. those also could benefit from being rethreaded.
Modified by Tyson at 12:09 AM 12/6/2005
Old Dec 5, 2005 | 11:06 PM
Blue Hybrid's Avatar
Default Re: (Tyson)
if that doesnt work, put a jack under the lower control arm, jack it up a bit, this will make the hub push down on the lower control arm, then you can tighten it, but make sure you have the nut on there correctly and its not stripped.
Juans_MX3
42
Jul 10, 2021 04:38 PM
Punker1234
15
Jul 10, 2021 03:53 PM
93(Civic)EG6
Sep 1, 2007 08:06 PM
ScottEK
17
Sep 21, 2002 06:23 PM
wildstallion
Jul 23, 2002 02:09 AM
