B18c1 in my EG needs new rings
I figured since I had to pull the pistons, I might as well geat some new ones while replacing the rings! I ordered some wiseco 12:1 comp. pistons. and a full gasket kit. Other than that what else will I need?? Its a stock GSR motor with Intake and exhaust.
Will I need tuning for it to run right? any other upgraded parts? the motor only has 49K on it. I believe it had a hard life of nitrous...
Thanks for any help given.
you obviously have compression once done, might as well look into some cams to complement the compression. yes, tune it. you will require more fuel with that much compression.
let me know if u need rings i can get you some. email me at stock93cx@yahoo.com
zx2gotboost
12
Jan 11, 2006 08:06 PM
