need help deciding on swap
Old Dec 5, 2005 | 05:49 PM
hondaefhatch89's Avatar
Default need help deciding on swap
i have a 89 civic si hatch it has stock 1.6 i what somthing fast easy and cheap that i cound do in my garage at home i what to do a dohc motor but just trying to decide which one is the easyest thanks peace
Old Dec 5, 2005 | 06:01 PM
boylovecar's Avatar
Default Re: need help deciding on swap (hondaefhatch89)
90-93 integra b18a motor and cable tranny.
Old Dec 5, 2005 | 06:19 PM
jdmcars.com's Avatar
The DOHC OBD0 non vtec ZC engine is going to be one of the quickest swaps for something simple. Requires not extra parts.
The other DOHC swaps are going to require more parts = more money. The Integra B18a or even the B16a are very good swaps, however they are going to require you to get the trans, engine mounts, axles, shift linkage were the ZC drops right in.
Any of the swaps are pretty easy with the correct list of parts to get though.
Old Dec 5, 2005 | 06:22 PM
Default Re: need help deciding on swap (jdmcars.com)
well i wanna do a h22 swap but every one says it kinda hard i know that will cost a little bit of money but if it is worth it i will do it
Old Dec 5, 2005 | 07:47 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaefhatch89 &raquo;</TD></TR><TR><TD CLASS="quote">well i wanna do a h22 swap but every one says it kinda hard i know that will cost a little bit of money but if it is worth it i will do it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaefhatch89 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 89 civic si hatch it has stock 1.6 i what somthing fast easy and cheap that i cound do in my garage at home i what to do a dohc motor but just trying to decide which one is the easyest thanks peace</TD></TR></TABLE>
----You just answered your own question
Fast and cheap = Keep the stock 1.6 and build a homemadeturbo kit,,run turboedit and have fun,,But if you must swap in a dohc motor then the 88-91 dohc zc motor is for you..Cheap and bolts in ..Isnt very strong but its a fun motor..
Old Dec 6, 2005 | 12:09 PM
lilblackhatch91's Avatar
You can build a budget turbo kit and run 5-7 psi safely on stock engine with very little money invested. As far as swaps i have a dohc zc and it very straight forward simple swap. I also have a friend with a stock si blaock and head with dohc zc rods and pistons(11.5-1 compression) in a 92 cx hatch and it runs great lots of torque. There are lots of options it just depends what level of dificulty you want .
Wanza
Dec 27, 2008 05:05 PM
MantisX
Nov 24, 2008 05:44 PM
blb8698
Aug 20, 2007 06:10 PM
eghatchomar
Dec 17, 2004 01:45 AM
MR CRX
14
Jun 22, 2002 08:09 AM
