b16 install; need some help!
Old Dec 5, 2005 | 05:30 PM
integra95gsr's Avatar
Default b16 install; need some help!
Well the b16a swap is almost complete, but im getting hung up on a few things. i was not the one who uninstalled a lot of these things so i dont know where they originally went! i need some help on what a few things are and where they go..
first, i have this cable. seems to be a speed type of cable where the heck does it go on the b16a?
.. then i was hooking up all the harness's and came to realize the plug from the injectors on the engine doesnt fit the one on the car?
and finally for now, ive been looking at some pictures and see that some b16a's dont have this, do i need it?
... followed by, well we got a new shift linkage with the engine from hmotors, and i dont know how to put it back together ... ugh
the old bushing doesnt fit in this..
Old Dec 5, 2005 | 05:32 PM
90civSi's Avatar
Default Re: b16 install; need some help! (integra95gsr)
hey that looks like my car lol
Old Dec 5, 2005 | 05:33 PM
1320spTurtle's Avatar
speedo cable...anymore ?'s
Old Dec 5, 2005 | 05:34 PM
fourthgenhatchB17's Avatar
Default Re: b16 install; need some help! (90civSi)
Im assuming you want to know what that is?? Speedo cable. Plugs into the VSS.
Old Dec 5, 2005 | 05:37 PM
90civSi's Avatar
Default Re: b16 install; need some help! (fourthgenhatchB17)
the problem is we dont know where it goes. it is a b16a1 obo0 with the y1 lsd tranny and we cant find where it goes to??
Old Dec 5, 2005 | 05:40 PM
sorry, my server was being uber lame and not loading all of the pictures. its all better. so yeah those are my questions!
Old Dec 5, 2005 | 05:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civSi &raquo;</TD></TR><TR><TD CLASS="quote">the problem is we dont know where it goes. it is a b16a1 obo0 with the y1 lsd tranny and we cant find where it goes to??</TD></TR></TABLE>
goes on the backside of the tranny, should have a little clip that holds it in there on the cleaner part like this
with the cover over it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civSi &raquo;</TD></TR><TR><TD CLASS="quote">and finally for now, ive been looking at some pictures and see that some b16a's dont have this, do i need it?
you don't need to connect anything to that. i forget what went to that in the original car, but i never had it connected to anything on my b16
Old Dec 5, 2005 | 05:52 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: b16 install; need some help! (1320spCRX)
For that bushing,I got the energy-suspension one for
84-87 CRX also 90-91 Integra at pep-boys and it was the same..
16-1101GC was the part number..
Old Dec 5, 2005 | 05:55 PM
hmm ok im starting to fashion an idea here. our VSS has a plug ontop of it, like its electronic and not cable.. is this bad?
Old Dec 5, 2005 | 05:58 PM
Buy My Coolness's Avatar
Default Re: b16 install; need some help! (88DXCRX)
I think the reason the cannon plug doesn't fit is because you are trying to use the fuel rail that came on the b16. You need to use the original d15 fuel rail on the b16 and everything should plug right up.
Old Dec 5, 2005 | 05:59 PM
WHAT! holy sh*t. are you serious about the fuel rail...
Old Dec 5, 2005 | 06:04 PM
RCautoworks's Avatar
Default Re: b16 install; need some help! (Buy My Coolness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buy My Coolness &raquo;</TD></TR><TR><TD CLASS="quote">I think the reason the cannon plug doesn't fit is because you are trying to use the fuel rail that came on the b16. You need to use the original d15 fuel rail on the b16 and everything should plug right up.</TD></TR></TABLE>
Fuel rail has nothing to do with it, its the engine wiring harness. If I can remember correctly , you can not use the sir harness because the plugs are different.
Old Dec 5, 2005 | 06:05 PM
that is the only plug that doesnt fit, all of the other ones fit correctly..
Old Dec 5, 2005 | 06:15 PM
Default Re: (integra95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">that is the only plug that doesnt fit, all of the other ones fit correctly..
The main big plugs should not fit, atleast one. And thats your problem.
only that cannon plug doesnt fit. would it matter if the civic is an SI? because it is..
Old Dec 5, 2005 | 06:18 PM
https://honda-tech.com/zerosearch
I'm telling you when you do a b16 swap, you are never suppose to use the sir harness cause of this reason.
g24jr's Avatar
Default Re: (90blackcrx)
is your tranny hydro or cable?
Old Dec 5, 2005 | 06:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch
I'm telling you when you do a b16 swap, you are never suppose to use the sir harness cause of this reason.</TD></TR></TABLE>
your link doesnt work..
its is a cable tranny..
Old Dec 5, 2005 | 06:23 PM
Rywire's Avatar
gottsta use the harness that came with the car man...
Old Dec 5, 2005 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">Well the b16a swap is almost complete, but im getting hung up on a few things. i was not the one who uninstalled a lot of these things so i dont know where they originally went! i need some help on what a few things are and where they go..
ok so we solved the cannon plug problem, i need to swap out the sir harness for the civic one. how about the other questions, our VSS is electronic. it is a Y1 LSD tranny.. the VSS has a plug ontop of it, it doesnt look like the other ones that the guy above has.
can i remove the thing that goes on the throttle??
Old Dec 5, 2005 | 06:28 PM
Malgerus's Avatar
Yes you can remove it. It's called a dashpot, just smooths out the engine as it drops out of driving RPM. I have mine off too.
Old Dec 5, 2005 | 06:30 PM
Malgerus's Avatar
You need to find a 90-93 Integra cable VSS, one from a JDM J1/S1 will work too. Hang onto that electronic one, you may decide to put in a 92+ guage cluster, which requires an electronic VSS&gt;
Old Dec 5, 2005 | 06:33 PM
Default Re: b16 install; need some help! (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">You need to find a 90-93 Integra cable VSS, one from a JDM J1/S1 will work too. Hang onto that electronic one, you may decide to put in a 92+ guage cluster, which requires an electronic VSS&gt;</TD></TR></TABLE>
will the 92+ gauge cluster fit in the 88-91 civic?
which clusters will all fit in?
Old Dec 5, 2005 | 06:34 PM
g24jr's Avatar
either get a diff speed sensor or swap clusters and wire that up
Old Dec 5, 2005 | 06:35 PM
Crx Jimmy's Avatar
the d series vss will fit the b tranny use the stock si one, it will fit and even bolt up, no mods necessary
