Suspension & Brakes Theory, alignment, spring rates....
lowering/new suspension
Old Dec 5, 2005 | 11:12 AM
obuhmyuh's Avatar
Default lowering/new suspension
allright, my shocks are pretty much toast, my del sol doesn't handle worth **** and it wobbles if im going over like 80 mph, im afraid the ****** thing is either gonna roll or spin out (again).
so im wondering how much it would cost just to replace my stock shocks, and then probably get some kind of lowering kit. im on a pretty tight budget, but i want my car to have control.
any help would be great.
thanks
Old Dec 5, 2005 | 11:20 AM
littleredcivic's Avatar
buy yourself some tokico or kyb replacement struts, then some tein springs...cheap and they should last a while.
Old Dec 5, 2005 | 11:34 AM
AutoXer's Avatar
Default Re: (littleredcivic)
I would only buy Koni for my car from now on. They're not that much more expensive than the other adjustable type shocks, and they'll rock with the stock springs. You can lower the perch as well, so you can get a better look.
Old Dec 5, 2005 | 11:36 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (AutoXer)
I would concur. You can get some Tein or H&R springs, and go with Koni's if you can.
Old Dec 5, 2005 | 12:07 PM
ekcivic9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">I would only buy Koni for my car from now on. They're not that much more expensive than the other adjustable type shocks, and they'll rock with the stock springs. You can lower the perch as well, so you can get a better look. </TD></TR></TABLE>
can you still get lowered w/ the stock springs? is that what you are set up as? how does it ride?
Old Dec 5, 2005 | 08:05 PM
you can lower on your stock stuff. but i'm sure your stock equipment is worn and not in great condition. the other members are right. i like koni too, but you mentioned budget.
Old Dec 5, 2005 | 08:20 PM
Sumslapper's Avatar
Year 3030
Im on Tokico Illuminas and ground control. If i turn them to the hardest setting, the car handles insanely good. And when im on the freeway, the car is super quiet and and has no shakes. If i turn it to the softest setting, it still handles pretty good but rides almost as nice as stock. I love my setup and have had no problems with it. I got my shocks new for 385$ on ebay and got some used ground controls for 120$. My setup was 505$. Thats about the price of some koni yellows. oh and im dropped about 2.2 inches on stock si rims, 50 series.
Old Dec 5, 2005 | 08:27 PM
mk97's Avatar
New User
i have kyb gr2's and they run FINE for a daily driver ona budget, dont always listen to those people who say kyb sucks. i also have friends who have gr2's w/ tein springs, h&r etc. run fine, a little bouncy on bumps but otherwise its great.
Old Dec 5, 2005 | 09:32 PM
Dave421's Avatar
Default Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">
can you still get lowered w/ the stock springs? is that what you are set up as? how does it ride?</TD></TR></TABLE>
Koni Yellows (Sports) allow three different spring perch heights. If I recall correctly they are in 5/8" increments from stock height down a little over an inch. The Neuspeed Koni Yellows have 5 increments to lower OR raise the ride height.
for a budget, you can look at the Koni Reds. Can handle almost as much as the yellows without the adjustment. If I recall correctly, if you decide down the road you want the adjustability, you can send them to Koni to have them converted still.
Personally, I won't run anything but Koni and I've used both the KYB & Tokico. Both were horrible in comparison in MY OPINION. For the price of some new shocks and springs, you can get the yellows and lower the perch for a lower ride height and then upgrade to some stiffer/lower springs down the road.
Old Dec 6, 2005 | 05:00 AM
AutoXer's Avatar
Yes. On the koni yellows, you can lower the spring perch that your stock springs will sit on. It will lower you about an inch.
I'm on Koni / GC combo right now; but if I didn't race my car, this is the setup I'd be running, with the possibility of upgrading to Eibach Pro-kits or the like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">you can lower on your stock stuff. but i'm sure your stock equipment is worn and not in great condition. </TD></TR></TABLE>
His springs should be fine. They have a very long life cycle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mk97 &raquo;</TD></TR><TR><TD CLASS="quote">i have kyb gr2's and they run FINE for a daily driver ona budget, dont always listen to those people who say kyb sucks. i also have friends who have gr2's w/ tein springs, h&r etc. run fine, a little bouncy on bumps but otherwise its great.</TD></TR></TABLE>
GR2s are a stock replacement only, and should not be used for anything with a higher springrate than stock. The bouncy ride is probably due to the springs being underdamped. I had the KYB AGXs in my car with Pro-Kit springs, and they ended up blowing very quickly, and caused serious handling problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">
For the price of some new shocks and springs, you can get the yellows and lower the perch for a lower ride height and then upgrade to some stiffer/lower springs down the road.</TD></TR></TABLE>
And they have a fantastic warantee and factory support. Should last the life of the car.
Old Dec 6, 2005 | 06:38 AM
I was talking about the struts, not the springs. Most people lower their cars using an aftermarket spring, not the perches on the strut since it only offers about one inch of adjustment.
Old Dec 6, 2005 | 08:03 AM
94eg!'s Avatar
#1 Super Guy
Loved
I too would go with Koni & stock springs (lowered 1.3"). Then after a while save up for some ground control coilovers. They make a special version for Koni's & you get to pick your spring rates too... Oh yeah, the lifetime warranty on both the shocks & the coilovers is a big plus
As for the individual spring perch settings on the shocks: The front has 2 positions, a stock position & -1" position (that trabslates to 1.3" at the wheel). The rear has 3 positions, a stock position, a -1" position & a +1" position.
Old Dec 6, 2005 | 10:30 PM
bmoua's Avatar
if you dont want to do the koni and stock springs then go with h&r sports or OE's and some kyb gr2s or adj....
Old Dec 6, 2005 | 10:39 PM
ekcivic9's Avatar
this is giong to sound stupid, but i always thought the spring determined the drop?
can i also drop w/ koni adj shocks? anybody have a picture of the setup and how it looks?
hows it ride?
Old Dec 6, 2005 | 10:40 PM
Tyson's Avatar
im currently running koni yellows in the rear of my crx with stock springs. just using because i got em for cheap and testing them out. im not really enamored wit hthem. id rather go back to my illuminas. just an opinion. ill put my illuminas back on when i have time.
Old Dec 7, 2005 | 04:59 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">this is giong to sound stupid, but i always thought the spring determined the drop?
hows it ride?</TD></TR></TABLE>
Springs do determine the drop. Konis have an adjustable perch (where the spring sits) on the shock body, so the spring will sit lower on the shock, which will lower the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
im currently running koni yellows in the rear of my crx with stock springs... im not really enamored wit hthem. </TD></TR></TABLE>
Interesting... since you got them for cheap, are you sure they're in good condition? I've driven quite a few stock cars with konis on track, and I'm always impressed by the control they have, even with less than ideal springs. That could translate into a bit more harshness on the road, but there's always a tradeoff with performance.
TigerLy
Jun 17, 2008 01:07 AM
ClubHead9786
Suspension & Brakes
28
Jul 31, 2007 07:27 PM
wlee2
Oct 6, 2004 08:57 PM
See Are X
Oct 18, 2003 07:53 AM
HaTcH_BmX
14
Aug 23, 2003 09:54 PM
