Good filler rod information
Old Dec 5, 2005 | 10:00 AM
RCautoworks's Avatar
Default Good filler rod information
Here are some good rules of thumb to help you select the correct filler metal:
4043 is a good general filler metal for most aluminum applications. Remember 2xxx and 7xxx series aluminum is generally not recommended if the application requires welding.
5356 is used for 5xxx series aluminum and is generally preferred if the finished piece will be anodized.
ER70S-6 is generally used for mild steel welding.
ER70S-2 is highly recommended for welding 4130 chrome-moly tubing in many applications.
ER80S-D2 is recommended for welding 4130 chrome-moly tubing if a higher strength, less ductile weld is required. If your weld will be heat treated to obtain optimum strength, then use a filler metal which matches the chemistry of your tubing, which neither 70S-2 nor 80S-D2 wires do.
Generally speaking, use a 1/16” diameter filler rod for applications where the material is 1/8” and less. Use a 3/32” diameter rod for 1/8” and thicker.
.john.
Welding / Fabrication
Mar 4, 2008 06:52 AM
55superbeetle
Oct 2, 2007 10:14 PM
JDMCRX
Sep 6, 2006 03:43 PM
jon volk
Nov 21, 2005 04:34 PM
