91 NSX 16x8
Old Dec 5, 2005 | 07:39 AM
ekim952522000's Avatar
Default 91 NSX 16x8
Will 91 nsx rear wheels fit on my type R they are 16x8?
Old Dec 5, 2005 | 07:41 AM
Erik95LS's Avatar
Default Re: 91 NSX 16x8 (ekim952522000)
any idea what offset they are?
Old Dec 5, 2005 | 08:07 AM
Default Re: 91 NSX 16x8 (Erik95LS)
yeah thats the only part i dont know about.
Anyone know where to find this info?
Old Dec 5, 2005 | 08:37 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know where to find this info?</TD></TR></TABLE>
http://www.nsxprime.com/FAQ/faq.htm
You are referring to the rear wheels of the '91-93 NSX. The offset is 60 mm, which is going to be a problem.
Old Dec 5, 2005 | 12:56 PM
typer_801's Avatar
Default Re: 91 NSX 16x8 (nsxtasy)
Major problem!!! 50mm is about the max up front and 40mm is about the max in the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Dec 5, 2005 | 01:02 PM
Kendall's Avatar
I know the front NSX wheels will work.
Old Dec 5, 2005 | 02:33 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I know the front NSX wheels will work.</TD></TR></TABLE>
Not really. The front NSX wheels have a different size center bore (the diameter of the hole in the middle, which is 70 mm, vs 64 mm for the ITR and the NSX rear). You then need to get hubcentric rings, which are impossible to get for NSX unless you do metal fabrication work, or you will be having all of the weight of the car supported by the lugs without the wheel fitting precisely onto the hub, which often results in vibrations due to the wheels being slightly off-center. Maybe you'll be one of the lucky ones who doesn't have any problems... but maybe you won't. Furthermore, even the front NSX wheels (which are 15x6.5 for the '91-93, 16x7 for the '94-01) have 55 mm offset, which will still be a problem in the rear, where they will rub on the suspension.
That's why the front NSX wheels aren't necessarily a good idea, either...
Old Dec 5, 2005 | 03:36 PM
Default Re: (nsxtasy)
ok guess that idea is out the window
Old Dec 5, 2005 | 04:09 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You then need to get hubcentric rings, which are impossible to get for NSX unless you do metal fabrication work, or you will be having all of the weight of the car supported by the lugs without the wheel fitting precisely onto the hub, which often results in vibrations due to the wheels being slightly off-center. </TD></TR></TABLE>
This isn't a unanimous opinion, though probably the official line given by wheel and car manufacturers.
First, the lugs don't hold up the weight of the car. The static friction between the rotor hat and the wheel does.
But yes, they do support the wheel until you tighten the lugnuts. Many people don't really care about hubcentric rings and don't have issues. My feeling is that the taper in the lugs keeps the wheel centered enough. I make sure not to put any weight on the wheel until the lugnuts are either torqued properly, or "almost" torqued properly.
-Chris
Old Dec 5, 2005 | 04:31 PM
BABY NSX's Avatar
Default Re: (Chris F)
I've been riding with NSX front wheels on my car since the early part of 1999 (without hub centric rings!) and I've NEVER had any issues...
F.Y.I. the hub centric rings that I find at wheel shops in my neck of the woods are all made of plastic... and commonly available for my application.
Old Dec 5, 2005 | 04:38 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">This isn't a unanimous opinion, though probably the official line given by wheel and car manufacturers.</TD></TR></TABLE>
It's also the UNofficial line that you'll hear from a lot of performance wheel and tire shops that have to deal with people who come to them with vibration problems, and find that this is often the cause of those problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Many people don't really care about hubcentric rings and don't have issues.</TD></TR></TABLE>
And many other people DO. As Clint Eastwood said in Dirty Harry: "you've got to ask yourself one question: 'Do I feel lucky?' Well, do ya, punk?"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX &raquo;</TD></TR><TR><TD CLASS="quote">F.Y.I. the hub centric rings that I find at wheel shops in my neck of the woods are all made of plastic... and commonly available for my application.</TD></TR></TABLE>
When I was thinking about putting NSX wheels on my ITR, I looked all over for hub centric rings at MANY shops, including the Tire Rack (yes, I went there and spoke to their experts), and was told that you just can't find them for the NSX wheels, end of story. And I have heard too many horror stories about plastic hubcentric rings (melting and otherwise not holding up to pressure or temperature) to ever want to use them.
Old Dec 6, 2005 | 06:42 AM
BABY NSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">When I was thinking about putting NSX wheels on my ITR, I looked all over for hub centric rings at MANY shops, including the Tire Rack (yes, I went there and spoke to their experts), and was told that you just can't find them for the NSX wheels, end of story. And I have heard too many horror stories about plastic hubcentric rings (melting and otherwise not holding up to pressure or temperature) to ever want to use them.</TD></TR></TABLE>
Not trying to sound like a smart a$$ but I went beyond thinking about it and actually did it without issue. A close friend of mine also has been running the same setup for years without problems... I guess we're just two lucky punks!
91civicsikid
14
Jul 24, 2008 06:31 PM
Francesco
Honda S2000
11
Jun 11, 2007 10:43 AM
JH4DC231
Jul 6, 2006 06:23 PM
ITRbroham
Honda S2000
Jan 17, 2005 02:53 PM
92jdmhatch
Apr 26, 2004 01:21 PM
