Inner C.V. Joint Puller???
Old Dec 5, 2005 | 07:37 AM
JG90CRX-Si's Avatar
Default Inner C.V. Joint Puller???
Has anyone ever used one of these? I've been searching to get an idea of how exactly it works. If you literally have to pull then I know it won’t work.
I've got a major problem with my passenger inner cv joint stuck in the tranny. I've tried for hours to get that bitch out and only managed about half an inch. I've broken the tips off tools, 4lb hammer, used an air hammer, used a pry bar with my brother behind me for extra leverage and nothing. I used more pressure pushing on that pry bar to try & pop it out then when I go to the gym and press 600+ pounds with my legs and that ***** won't budge! I guess I need to work out more!
I took off the intermediate shaft to pound it out the other side too and no luck. I've done the 1/4 turn rotation method and put screw drivers/air hammer bits on both sides for equal leverage. I've already damage the outer casing of the tranny so I don't want to do this anymore if there is another way.
Any other suggestions would be greatly appreciative!!
Johnny G.
Old Dec 5, 2005 | 09:48 AM
RCautoworks's Avatar
Default Re: Inner C.V. Joint Puller??? (JG90CRX-Si)
Did you get it out of the hub ?
Old Dec 5, 2005 | 10:11 AM
JG90CRX-Si's Avatar
Default Re: Inner C.V. Joint Puller??? (90blackcrx)
"Did you get it out of the hub ?"
Yea, that was the easy part. I took the driver side off with-in five minutes, compressors rock, just bought it last week. Too bad it's not helping with this situation though.
JG
Old Dec 5, 2005 | 02:25 PM
JG90CRX-Si's Avatar
Has anyone ever used a CV joint puller?
Bump....
Old Dec 5, 2005 | 03:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG90CRX-Si &raquo;</TD></TR><TR><TD CLASS="quote">
Bump.... </TD></TR></TABLE>
Show me a picture of what you are talking about, I would imagine something like this might work.
Old Dec 5, 2005 | 03:46 PM
InJ3cted's Avatar
lol never had a stubbourn one like that but usually a pry bar and a quick pop at it will losen it....
Old Dec 5, 2005 | 03:55 PM
91civicEX's Avatar
Default Re: Inner C.V. Joint Puller??? (InJ3cted)
so you cant get the axle out of the intermediate shaft right? i had the same problem on my moms 96 accord. i wrestled with that bitch for hours and finally just put it back together. i ended up buying a new intermediate shaft from the wrecker
Old Dec 5, 2005 | 04:12 PM
JG90CRX-Si's Avatar
Default Re: Inner C.V. Joint Puller??? (91civicEX)
90blackcrx, that's the puller I'm talking about. Do you just pull or there a way for this to have some type of torque applied to pull out the joint?
InJ3cted, at this point I don't think Superman could pull this out! If that's the case I'm SCREWED!
91civicEX, the intermediate shaft was easy to pull out. I only did this to see if I could knock out the passenger (stuck one) joint from inside the tranny. I've got an air hammer but I didn't use it from the inside of the tranny for fear of accidentally chipping that part or leaving pieces of the joint stuck inside.
Thanks for the replies, keep the ideas coming please!!
JG
Old Dec 5, 2005 | 04:42 PM
HiProfile's Avatar
Looks like that tool posted is a slide hammer. Heavy handle slides, impacts that spherical stopper, and jolts the cv joint out.
My only other suggestion would be to stick a heavy duty centerpunch in through the other side. Axles usually have a dimple in the center on the end of the splines, which lets the centerpunch not move when you wack it with a BFH. The other suggestion would be to rotate it while trying to remove it (be with a crowbar, centerpunch, etc).
Old Dec 5, 2005 | 05:20 PM
ludesrv's Avatar
Air shizzel it loose. Worked on a friend crashed crx with b16a.
Old Dec 5, 2005 | 06:57 PM
JG90CRX-Si's Avatar
Default Re: (ludesrv)
Thanks again for the replies everyone.
"HiProfile", my buddy just told me the exact same thing on how the CV puller worked, to bad I didn't know about this before. He says to use a 10lb slide hammer, so I will see if this works.
I will try sometime this week to rent one and I will post the outcome.
"ludesrv", I tried the air hammer too but no luck, I've got holes/dents in the CV housing to prove it!
JG
PC509
Sep 10, 2010 11:37 AM
soysauce90CRXsi
Sep 10, 2008 09:15 AM
georgelimas
Mar 30, 2008 05:52 PM
crx18c1
Apr 18, 2007 06:13 PM
explictness
Dec 26, 2005 12:28 PM
