Front sway bar?
Old Dec 5, 2005 | 07:35 AM
ekim952522000's Avatar
Default Front sway bar?
Is there anyway to put a front sway bar on my 97 DX without EX arms?
Old Dec 5, 2005 | 11:46 AM
Default Re: Front sway bar? (ekim952522000)
Will integra front arms work?
Old Dec 5, 2005 | 11:48 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You can use Civic EX/SI LCA's or Integras. They will bolt up and have factory swaybar holes.
Suspension Techniques makes bars for the front and rear for people with no factory holes.
Old Dec 5, 2005 | 12:20 PM
kyden's Avatar
for an ex front sway you need ex front control arms.
for an si front sway you need si front control arms.
the two have different mounting points.
Old Dec 5, 2005 | 12:35 PM
d16rice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">Is there anyway to put a front sway bar on my 97 DX without EX arms?</TD></TR></TABLE>
I just put LX sedan front sway bar on my '97 DX hatch.
This is what you'll need:
- Sway bar (LX)
- Brackets (LX or Energy suspension)
- Endlinks (LX or Energy suspension)
- Partial control arm.
You don't have to replace the whole control arm, it's a lot easier to replace just the part with a hole for the sway bar.
If you haven't noticed yet, it's made out of two pieces.
One is straight (you won't need this one).
And the other is kind of like an "F," that's the piece you need.
Here's a picture:
If you just replace this instead of the whole thing, you won't have to mess with ball joints and what not.
Old Dec 5, 2005 | 01:34 PM
Archidictus's Avatar
Unceasing Measure
The Suspension Techniques bars are great and require nothing aside from whatever your car came with stock .
I bought aftermarket rear LCAs for my 93 Si anticipating purchasing a nice rear swaybar and ended up not needing them due to the ST's construction. Oh well, a little bling never hurt anyone
Old Dec 5, 2005 | 03:21 PM
T-RO's Avatar
Default Re: Front sway bar? (d16rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">I just put LX sedan front sway bar on my '97 DX hatch.
- Sway bar (LX)
If you just replace this instead of the whole thing, you won't have to mess with ball joints and what not.</TD></TR></TABLE>
This SHOULD work for 92-95 Civics as well. This weekend I grabbed the same exact pieces off a 94 EX and plan on throwing them on my 92 CX. The CX LCA,s have the holes for the "F Piece"
Old Dec 5, 2005 | 03:33 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The Suspension Techniques bars are great and require nothing aside from whatever your car came with stock .</TD></TR></TABLE>
Are you saying if i buy suspension technqiues sway bars It comes with everything i need to put a front sway bar on? That woulb be great.
Old Dec 5, 2005 | 04:10 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (ekim952522000)
The DX didnt come with a FRONT sway bar? On a FWD car? Damn Honda, way to cut costs....
Old Jan 12, 2006 | 06:52 PM
* B A N N E D *
Default Re: (Redline96LX)
anyone know what the diameter of the LX front sway bar is?
Old Nov 21, 2006 | 11:54 PM
BrakeExpert's Avatar
The 96-00 Civic EX and LX came with a 22mm sway bar, the Si and CTR came with the front 26mm sway bar but took different LCAs.
Old Nov 22, 2006 | 04:39 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">The DX didnt come with a FRONT sway bar? On a FWD car? Damn Honda, way to cut costs....</TD></TR></TABLE>
that things sways like a boat too. My bro's gf has a DX...no sway bar FTL
Old Nov 22, 2006 | 07:59 AM
kaiba's Avatar
Don't tell me you never pulled ITR ones out. If not, you suck.
Old Nov 22, 2006 | 08:13 AM
SOHCejcivic's Avatar
Default Re: (kaiba)
dx lca's don't have the hole for the endlink. 96+ ex/99+ si lca's are your best bet. you can use dc integra lcas, but you'll need to switch over the front section of the control arm onto the rear section of the integra arm.
Old Nov 22, 2006 | 09:07 AM
Default Re: (DeadEnd9009)
What's an FTL?
Old Nov 22, 2006 | 09:29 AM
kaiba's Avatar
Default Re: (Redline57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline57 &raquo;</TD></TR><TR><TD CLASS="quote">What's an FTL?</TD></TR></TABLE>
FTL = For the lose
FTW = For the win
Old Nov 22, 2006 | 01:20 PM
Blk00EJ8's Avatar
Default Re: (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">dx lca's don't have the hole for the endlink. 96+ ex/99+ si lca's are your best bet. you can use dc integra lcas, but you'll need to switch over the front section of the control arm onto the rear section of the integra arm. </TD></TR></TABLE>
But like already stated, Ex and Si LCA's are completely different.
1. Ex is two piece vs the Si one piece.
2. Ex does NOT use endlinks and the Si does.
Old Nov 22, 2006 | 03:00 PM
kaiba's Avatar
Default Re: (EKcivicEX)
99-00 SI
96-00 EX
92-95 Civic w/swaybar
94-01 Integra. Somewhere along the line honda change its swaybar/endlink design.(picture on rigtht)
Old Nov 22, 2006 | 03:02 PM
kaiba's Avatar
[QUOTE=EKcivicEX]
2. Ex does NOT use endlinks and the Si does.[/
QUOTE]
1. Correct. Also, Ex is cast iron and the SI is metal.
2. EX do have endlink but different style.
Old Nov 23, 2006 | 09:51 PM
Blk00EJ8's Avatar
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">
2. EX do have endlink but different style.</TD></TR></TABLE>
Mine didn't exactly resemble an endlink... I suppose it is, even though the sway bar is practically bolted onto the arm with very little room for movement. That, and the holes for the links on the Ex bar are parallel to the ground, instead of perpendicular like the Si.
Old Nov 23, 2006 | 09:54 PM
EK k kay's Avatar
http://www.jdmuniverse.com/for...ybars
Old Nov 23, 2006 | 11:52 PM
kuja396's Avatar
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=EKcivicEX]
lmao isn't cast iron also a metal?
Old Nov 24, 2006 | 02:07 PM
kaiba's Avatar
Default Re: (kuja396)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja396 &raquo;</TD></TR><TR><TD CLASS="quote">lmao isn't cast iron also a metal? </TD></TR></TABLE>
SHUT UP!!! you know what mean.
HustonB
13
Jan 3, 2013 11:36 AM
hondacurious
Jul 25, 2010 08:49 PM
Djole_V
Suspension & Brakes
Dec 6, 2006 04:11 PM
Jon V
May 13, 2004 10:28 AM
TreDEE
Sep 30, 2001 11:49 PM
