crx 4 wheel disc MC in a ef civic - any change?
Old Dec 4, 2005 | 09:18 PM
sugarloafpkwy's Avatar
Default crx 4 wheel disc MC in a ef civic - any change?
Has anyone tried this combination? A crx si MC with 4 wheel dics on an ef hatch with drums. Would that be an improvement or a problem?
Old Dec 4, 2005 | 09:21 PM
EL Vap133's Avatar
Default Re: crx 4 wheel disc MC in a ef civic - any change? (sugarloafpkwy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarloafpkwy &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone tried this combination? A crx si MC with 4 wheel dics on an ef hatch with drums. Would that be an improvement or a problem?</TD></TR></TABLE>
It would do nothing for you.
Old Dec 4, 2005 | 10:16 PM
dr_latino999's Avatar
Now a Civic EX master cylinder, that will help you out
Old Dec 5, 2005 | 06:34 AM
Default Re: crx 4 wheel disc MC in a ef civic - any change? (EL Vap133)
well the bores are different aren't they? Im saying because I have one installed currently and my brakes suck. need to know if I should go buy normal MC.
Old Dec 5, 2005 | 10:56 AM
Rob.'s Avatar
Default Re: crx 4 wheel disc MC in a ef civic - any change? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Now a Civic EX master cylinder, that will help you out </TD></TR></TABLE>
can you put a civic EX MS on a civic with rear drums ?
Old Dec 5, 2005 | 11:15 AM
Targa250R's Avatar
be professional
Improvement of what?
Pedal feel? Only if your current MC is smaller than 7/8".
Stopping distances/braking power? No, it won't make any difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarloafpkwy &raquo;</TD></TR><TR><TD CLASS="quote">well the bores are different aren't they? Im saying because I have one installed currently and my brakes suck. need to know if I should go buy normal MC.</TD></TR></TABLE>
Please evaluate on "brakes suck."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">
Of course. The master cylinder has nothing to do with whether you have drums or discs.
Old Dec 5, 2005 | 07:15 PM
Default Re: crx 4 wheel disc MC in a ef civic - any change? (Targa250R)
"brakes suck" = pedal requires excessive pressure to stop vehicle.
I aasumed the crx si has a 15/16'' MC because it has rear discs. I figured the larger bore would make the pedal stiffer. I'm going to put in a proper MC tomorrow and see if the problem goes away.
It feels like glazed pads but i replaced them and rotors but no change. It's not the brake booster.
Old Dec 5, 2005 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">
you need the proportioning valve off a crx si. </TD></TR></TABLE> Do you really?
https://honda-tech.com/zerothread?id=1446096
Old Dec 5, 2005 | 10:59 PM
Tyson's Avatar
theres no reason you cant get your stock brakes to stop the car properly.
i hear that you changed pads and rotors. thats good. but did you bleed the lines properly? is it "mushy"? then its still likely youve got air in your system. also, old calipers need to be rebuilt, seals go bad, let air in, leak fluid, small enough you wouldnt notice a leak, but will affect the performance.
changing the rear brakes does very little for improving your hard, threshold braking performance. so little weight is over the rear during braking, they dont contribute much, and shouldnt be the focus of looking for improvement.
tires also have a tremendous affect to braking performance. thats really whats doing the work. you need good rubber for that, not old hard stuff.
ive heard from several experienced drivers (ill call them racers) who have switched from drums to discs in the rear, and said there was no difference in performance. just easier to maintain.
Old Dec 5, 2005 | 11:02 PM
Blue Hybrid's Avatar
Default Re: crx 4 wheel disc MC in a ef civic - any change? (Tyson)
i put si brakes on my ef with drilled and slotted rotors, it stops alot better. stock ef's in general dont stop for ish
oh yeah, check if your vaccum line to the brake booster is cracked or not hooked up properly, that would make a big difference
Old Dec 5, 2005 | 11:06 PM
Tyson's Avatar
Default Re: crx 4 wheel disc MC in a ef civic - any change? (gold EF)
sounds like you benefited from just putting new rotors on your car.
stock EF's stop great. 15-18 year old brakes dont. maintain your brakes to like new condition, and theyll work great again.
Old Dec 5, 2005 | 11:09 PM
actually, i rebuilt the entire stock brake system before i did the si conversion it still didnt stop for beans, my buddys ef's are the same. the bigger tires do help though
agendadjs
22
Dec 3, 2007 03:28 PM
d357r0y
Nov 3, 2007 08:32 AM
whiteguyndahood
Nov 4, 2006 07:48 AM
JDM_EK_JOE
Jun 11, 2006 06:04 PM
murena
24
Feb 1, 2005 08:18 PM
