Would 90 CRX Si front brakes work on my 93 Civic?
Need more info...
What do you mean by brakes?
Brake Pads? Brake Rotors? Brake Calipers? Brake caliper mounting brackets? The whole front knuckle?
Does your Civic have the 10.2" front rotors? (Si/EX, w/ABS)
The whole assembly, and no it doesn't have the Si/Ex rotors. Hey, did you want to buy 92-95 shift linkage? I have a set from my hatch that Im not using. (Im H22 powered now.)
Cause the CRX Si took the 10.3" front brakes and the 93 civic of his probably has the shitty 9.5" brakes. If you swap the whole knuckle, yes it will work, and your stock brake line will bolt up, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">Cause the CRX Si took the 10.3" front brakes and the 93 civic of his probably has the shitty 9.5" brakes. If you swap the whole knuckle, yes it will work, and your stock brake line will bolt up, etc.</TD></TR></TABLE>
No, the CRX Si had the 9.5" brakes. All USDM CRXs had 9.5" front disc brakes.
No the CRX knuckle is different then the 92-95 knuckle.
Modified by Surewin at 6:29 PM 12/6/2005
pelotudo
Apr 12, 2003 12:17 PM
