GSR W/ CTR cams
well i was able to make 171hp and 131ft/lbs of torque
My Setup:
Stock GSR bottom end
CTR Cams
ITR valvesprings
Skunk 2 intake mani
DC sports 4-2-1 header ( flattened collector)
full 2 1/2 exhaust
Short Ram intake
Tuned with Crome
Dyno Chart:
My Setup:
CTR Cams
ITR valvesprings
Skunk 2 intake mani
full 2 1/2 exhaust
Short Ram intake
Tuned with Crome
Dyno Chart:
im building it this winter... the new setup should put me in the 200 range it should be around 12.8/1 cr
setup:
p30 pistons
2 layer head gasket
Mill the head .025
head work
cams??? not sure yet
setup:
p30 pistons
2 layer head gasket
Mill the head .025
head work
can't go wrong with skunk2 stage 2's or you can go the cheaper right with just as much performance using blox stage 2's from what i heard
(skunk 2 clones)
(skunk 2 clones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motoman »</TD></TR><TR><TD CLASS="quote">Could you give more details about your tune? I.e., vtec engagement rpm, secondaries opening rpm, etc.... Also, why the crazy a/f readings?</TD></TR></TABLE>
the crazy air fuels were that motor on a stock gsr map
MassScene
10
Mar 10, 2005 04:28 PM
