How many amps does it typically take you guys to weld sch 40 stainless?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race »</TD></TR><TR><TD CLASS="quote">300 amps..
Now.. seriously.. we need a thickness.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cefed »</TD></TR><TR><TD CLASS="quote">he said sch 40</TD></TR></TABLE>
I'm wondering also, if I should do less amps and 2 passes, or high amps and 1 pass. I will really only be welding turbo manifolds.
130 amps (obviously i dont floor the pedal) at the power source. When welding stainless, you need to get it hot really fast, and go like hell when you weld it. Otherwise you will burn the carbide up back into the chromium and stuff. No really its true. If you go slow you will bet a lot of sugaring, and your weld zone will loook like ****. No color = bad. You want it to burst with color when its done.
Here is some that i've done
the top side bead that you see is me going hot and fast, the other side you can see the back has sugaring. My instructor told me to go slow, with low amps. And you see what happened.
Notice the heat effected zone. Think of welding stainless as boiling a pot of water. Lower amps doesn't mean you won't burn up the metal. It just takes longer to get it hot, and by the time you have gotten hot enough to weld, your h.e.z. is out of whack, and the rest of your weld will be too hot to maintain good color and still retain good stainless characteristics. Weld hot and fast.
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">
i would two passes... one root pass for penetration then a 2nd for that cool look everyone wants, lol
</TD></TR></TABLE>i would two passes... one root pass for penetration then a 2nd for that cool look everyone wants, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurboJesse »</TD></TR><TR><TD CLASS="quote">still looks alittle hot...
usually 80-100 amps for me and im never full pedal..</TD></TR></TABLE>
I agree. Those welds were from a long time ago, and they are barely within color.
GapxGuy
Audio / Security / Video
Jan 12, 2007 03:57 PM
Loco Honkey
Welding / Fabrication
Jun 12, 2006 05:38 AM
