b16 VTEC head package (ls/vtec conversion package deal)!!!
$600!
Already have a LS motor in your car? looking to get more power? a simple ls/vtec conversion can acheive that, but why not top it off with the perfect power with a couple of oem reliable parts?
a vtec head would do the trick... im offering a chance to improve the power on your current set up with what i'll call a "ls/vtec head add on package"
included:
-first gen B16 head // resurfaced not too long ago (no distributor/valve cover) $400 value
-resurfacing was $80
-JDM itr intake manifold $220 value
-golden eagle ls/vtec conversion kit (need new headgasket can be ordered at golden eagles website ...$150 dollar value. (this kit is basically already installed, the head is plugged with no leaks, all you have to do is screw the fittings onto the block side.
-ARP head studs $100 value
totaled up ..used price would be $950 not to mention little things here and there like str cam seal... etc
take ALL OF THIS FOR $600!
things you would need (if you already have a complete ls in y our car):
gsr or itr timing belt, vtec water pump, new head gasket, valve cover, distributor and wires/spark plugs (unless you hack a leg off the LS dizzy which would work fine), and a vtec ecu
Modified by r a n d e E e at 12:14 PM 12/29/2005
included:
Hey i was thinkin about doin my 91 teg ... the "LS/VTEC" swap from my O.G. b18
Sooooo
All u basically need:
16 head, cams, bolts, ecu, spark plugs, intake manifold, distributor, ( maybe header), ..... forgettin anything else ??
On a decent price, how much u think would cost doin it your self, or profess ??
Sooooo
if you buy mine... you got almost everything already... including some performance parts... you can do it yourself for free.. just be very careful and follow instructions
