help: studs aren't the same? weird
Old Dec 4, 2005 | 06:31 PM
rewerbcrx's Avatar
Default help: studs aren't the same? weird
i used the knuckles from a 91' integra and the stock steelie rims wouldn't bolt up to them... i thought they both had 4x100 bolt pattern? odd to me..... anyone have the answer or a solution... the rims aren't bent, and the studs are to wide...
Old Dec 4, 2005 | 07:18 PM
rewerbcrx's Avatar
Default Re: help: studs aren't the same? weird (rewerbcrx)
it gets depressing when no one responds lol
Old Dec 5, 2005 | 07:01 AM
DelSolDon's Avatar
did you pull the front knuckles off the integra yourself, or did you buy them from somebody already removed? even if you did pull them from the car, there's no saying that the previous owner didn't swap something else on there. try to get ahold of a 4x114 wheel or aftermarket wheel with a universal 4-lug pattern and see if they fit. easiest solution (not really the cheapest) if you do in fact have 4x114 in the front and 4x100 in the back would be to buy some aftermarket rims that have the universal 4-lug pattern and use those on your car. more difficult (but should be cheaper) would be to swap the knuckles out with some that are actually 4x100.
Old Dec 6, 2005 | 05:27 PM
rewerbcrx's Avatar
Default Re: help: studs aren't the same? weird (DelSolDon)
i did pull the knuckles off the donor teg and the engine was the original engine WTF.... i don't understand... is there a measurement i could take from one stud to the other to comfirm that its either one or the other... ?
Old Dec 6, 2005 | 05:29 PM
Crx Jimmy's Avatar
yes just measure is it 100 ir 114
Old Dec 6, 2005 | 05:30 PM
Crx Jimmy's Avatar
Default Re: help: studs aren't the same? weird (Crx Jimmy)
oh if they are stock civic steelies in 14 inch ive seen them not fit integras it hits the caliper, but integra 14 steelies fit go figure ???
BREEZEDOLLAZ
Jan 31, 2012 04:16 PM
djs87
Apr 28, 2008 05:54 PM
inspireAZN
Dec 11, 2007 06:06 AM
gribbs
Apr 20, 2005 09:40 PM
ken zai
Apr 15, 2002 10:16 PM
