Head Gasket problems, water in Oil.
Old Dec 4, 2005 | 05:14 PM
caminSi's Avatar
Default Head Gasket problems, water in Oil.
I have an 00 si, and i busted a valve, i took it all apart, replaced the valve, had the head decked, got a new head gasket, put it all back together, and when i cranked it up and ran it for a little while there was water all in the oil???? there was no water in the oil at tear down. what the heck is the problem??? please help me.
Thanks
Old Dec 4, 2005 | 05:17 PM
my_slow_civic's Avatar
Default Re: Head Gasket problems, water in Oil. (caminSi)
When you pulled the head off, did any coolant leak out?
Old Dec 4, 2005 | 06:02 PM
caminSi's Avatar
Default Re: Head Gasket problems, water in Oil. (my_slow_civic)
yeah, i drained the radiator, but not the block, but after i noticed the water in the oil, i changed the oil, and then ran it again but still some water????
watcha think
appreciate the help
Old Jul 25, 2006 | 08:10 AM
r1mshady's Avatar
i got this same problem with my si
wat to do?
Old Jul 25, 2006 | 09:09 AM
Turbo_y8's Avatar
Default Re: Head Gasket problems, water in Oil. (r1mshady)
Sounds like a head gasket issue still. I personally wouldnt keep driving. Oil and water dont mix. And if your running coolant that can contaminated the oil.
Old Jul 25, 2006 | 09:52 AM
gents97civ's Avatar
If it has water in the oil still you have a headgasket issue. Change it asap. Water in your oil will ruin bearings in no time.
Old Jul 26, 2006 | 06:36 AM
gents97civ's Avatar
Also when you replace the headgasket try using copper spray or even better Indian Headgasket sealer made by permatex
Old Jul 26, 2006 | 07:36 AM
jbiel's Avatar
Default Re: (gents97civ)
Did you ever overheat the car?
Check the block for warpage with a straight edge.
Old Jul 26, 2006 | 08:30 AM
YoungKadafi's Avatar
dont use anykinda sealant, BAD, i have made that mistake JUST DONT!
Old Jul 27, 2006 | 07:52 AM
gents97civ's Avatar
sealant can be very helpful if it is used properly
Justin Branham
Feb 22, 2019 09:06 PM
hondaboyz94si
Dec 10, 2005 06:13 PM
ECKOTYPER
Jan 28, 2004 01:17 PM
Raymund
Aug 8, 2003 07:41 PM
