need help is it the timming?
Old Dec 4, 2005 | 04:35 PM
EDVxRICHARD's Avatar
Default need help is it the timming?
i just started my motor i have a 1992 honda civic cx and i just put in a B16......i started it and when you just let it idle it wont even idle itll just die.....but when you rev it up to about 2 3 K it sounds just like a WRX wit an exhaust not clean like it but it bobs just like that........can it be my timming or the dizzy?......i fyou need more info let me know......
Old Dec 4, 2005 | 04:48 PM
Default Re: need help is it the timming? (EDVxRICHARD)
Bump
Old Dec 4, 2005 | 04:50 PM
platinum00's Avatar
can you hold the idle at below 1000 with the gas.
is your idle set to low, to keep it running.
did you check the timing. what's it set at. 16BTDC??
platinum.
Old Dec 4, 2005 | 06:54 PM
Default Re: need help is it the timming? (platinum00)
im thinkin it is the timming because the timming belt is fucked up....i didnt realize it until i removed the valve cover and the teeth on the timming belt are missing (not sure but my assumtions) so that knocked it off......but i am goin to run some tests as in if the dizzy is workin properly and checkin the spark plugs and all that good stuff
Old Dec 4, 2005 | 07:10 PM
movingIIshadow's Avatar
No teeth on the timing belt?? Thats a problem alright.
Old Dec 4, 2005 | 07:15 PM
Default Re: need help is it the timming? (movingIIshadow)
well not on everysingle one of them only one section of the timming belt will that change the timming?
Old Dec 4, 2005 | 09:12 PM
Jorsher's Avatar
Hate to be an ***, but "timming" is really annoying. It's spelled "timing." If it is missing teeth, that is most likely the problem. Fix that first.
Old Dec 4, 2005 | 09:23 PM
Tony_EM1's Avatar
well if the belt is missing teeth dont even do ne test... replace that belt asap befor nething else..
Old Dec 5, 2005 | 06:15 AM
platinum00's Avatar
Default Re: (code415)
even if you fix the problem with out swaping the belt, get a new one ASAP. that's just a disaster waiting to happen.
platinum.
Old Dec 5, 2005 | 07:18 AM
Default Re: (platinum00)
yea i will i just gotta wait till i get my next check.....ahaha but i will............hey update i have just searched around for the firing order and tell me if im wrong or not........but by lookin at the dizzy starting from the top left is 3 the top right is 4 the bottem left is 1 and the bottom right is 1 correct? and then the cylinders would go by the order of from left to right 1 2 3 4 correct? well i checked it and this is how it looks like............the 4th one from the dizzy is connected to the first cylinder.........the 3rd one from the dizzy goes to the second cylinder........the 2nd from the dizzy goes to the third cylinder.........and the 1st from the dizzy goes to the fourth cylinder......incorrect? i think so cuz ive talked to someone and they told me in this order 1,3,4,2 thats correct?.......and the second cylinder is the only one firing correctly so i guess that explains why my car sounded like a Shitty *** WRX and when i full throttle it it sounds like a shitty 2 step
gokblok
Aug 1, 2013 04:20 PM
ShinobiLude
Nov 8, 2006 08:40 AM
llevity
Jul 12, 2005 02:39 PM
crix351c
Feb 27, 2005 10:30 AM
curiousgpnoy
Jan 20, 2004 11:16 AM
