ecu
Old Dec 4, 2005 | 03:51 PM
hondateen17's Avatar
Default ecu
i have an automatic 00 civic ex. i dont want to do a tranny swap but i want to put an obd1 into it. i need to know what i need exactly like which ecu and harness. thanx
Old Dec 4, 2005 | 04:00 PM
nekoabandoned's Avatar
Default Re: ecu (hondateen17)
just throw a p28 with a conversion harness,and if u want to squeeze a little more power from ur autobandwagon then get it chipped. itll cost ya about $200 for the p28,getting it chipped and the harness. but seriously go manual
Default Re: ecu (nekoabandoned)
oh and i forgot to ask why are you doing this?
Old Dec 4, 2005 | 04:19 PM
SVOboy's Avatar
Good advice, neko.
Old Dec 4, 2005 | 04:32 PM
erubio14's Avatar
Default Re: (SVOboy)
yea dude go manual.
Old Dec 5, 2005 | 12:06 PM
what harness do i go with? i am doing this so i idle better and i dont have error codes.
Old Dec 5, 2005 | 03:13 PM
SVOboy's Avatar
Just look around for ecu harness diy stuff, and do it yourself. :-)
Old Dec 5, 2005 | 03:18 PM
where is the best place to get the ecu?
Old Dec 5, 2005 | 03:29 PM
SVOboy's Avatar
Which ecu are you gonna be looking for? Auto p28? d16y8 engine right?
Old Dec 6, 2005 | 10:35 AM
If the p28 fits my car then yes. and yes it is a d16y8. but what harness do i need besides the diy?
Old Dec 6, 2005 | 10:47 AM
skankz_em1's Avatar
Default Re: (hondateen17)
you need the obd2b to obd 1 harness
Old Dec 6, 2005 | 10:42 PM
Default Re: (white eg in tha LBC)
my god why dont you just go mani? and if u want a chipped ecu go to http://www.phearable.net/ cost u $175 tops and the tranny,just go to a junk yard and get all the parts for 250 tops
bottom line just think $400= life is good
Old Dec 7, 2005 | 10:45 AM
skankz_em1's Avatar
Default Re: (nekoabandoned)
all u need is pedals, linkage, clutch lines, clutch slave cylinder, clutch, flywheel, clutch bolts, manual flywheel bolts, tranny and the manual tranny mounts (top mount, L bracket, and vibration mount) the swap is easy if you know what you are doing..
nels450
Oct 10, 2008 07:59 AM
EJ8FERIO
Aug 18, 2007 03:17 PM
bsuperior2
Sep 10, 2003 07:37 PM
