Size of Window Washer Fluid Resivoir
Old Mar 14, 2002 | 10:11 AM
zojirushi's Avatar
Default Size of Window Washer Fluid Resivoir
Anyone know the volume of the container??
Old Mar 21, 2002 | 08:21 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Size of Window Washer Fluid Resivoir (zojirushi)
US : 2.6 Quarts (2.5L)
Canadian: 4.8 Quarts (4.5L)
Old Mar 21, 2002 | 11:30 PM
NWPNOMORE's Avatar
Banned
Default Re: Size of Window Washer Fluid Resivoir (shamoo)
all i know is that thing full weighs a lot. Drain it or just pull the whole thing out.
Old Mar 22, 2002 | 05:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That can't be right. My washer tank has been bone dry since about November because I only use water and didn't want it freezing up. The other day I just poured a gallon of water into it and it still didn't fill it all the way up.
Old Mar 22, 2002 | 05:44 AM
Big Teggie's Avatar
Default Re: Size of Window Washer Fluid Resivoir (PatrickGSR94)
I can only fill mine up with like 2/3 a gallon of washer fluid. I guess if i got rid of it i can save like 8 lbs. total. The resivoir itself aint that heavy,liek 2 lbs. Its just plastic.
Old Mar 22, 2002 | 06:02 AM
betsuni's Avatar
Default Re: Size of Window Washer Fluid Resivoir (NWP4LIFE)
weight reduction
did that to mine
Old Mar 22, 2002 | 08:14 AM
shamoo's Avatar
Those are the specs that the Acura Integra manual give. Where are you from? 4 quarts=1 gallon.....just checking.
Old Mar 22, 2002 | 09:15 AM
Community Builder
My car was originally bought in Memphis, so it's def. a USDM car. Just the other day I filled up a pitcher w/ water and poured it in there....
*wait* I was thinking I used a different pitcher, the one I used may indeed have been 2 quarts... I'll have to check, because I know I have a 4-qt. pitcher, but that's the one I keep lemonade in.
[Modified by PatrickGSR94, 12:15 PM 3/22/2002]
Old Mar 22, 2002 | 09:19 AM
zojirushi's Avatar
i wanna use my resivoir for holding the water for water injection
Old Mar 22, 2002 | 09:49 AM
Community Builder
You'll have to drain it and not be able to use it during winter, though.
Old Mar 22, 2002 | 12:11 PM
zojirushi's Avatar
in the winter, all i have to do is add 25% rubbing alcohol
TooManyTickets
30
Jul 16, 2007 09:45 PM
EK VTi
Acura TL, RL & ZDX
Dec 24, 2005 01:16 PM
oscar_lopez03
Jan 20, 2005 08:48 AM
Wazup
Jan 14, 2003 01:11 AM
94preludeVTEC
Dec 12, 2001 08:56 AM
