frozen E-brake. gear slips when parked!!
Old Dec 4, 2005 | 01:58 PM
SIMATIC's Avatar
Default frozen E-brake. gear slips when parked!!
i got a 98 accord Ex 5 speed. 145k.
Problem 1.
in the winter i cannot use my emergency break when it gets around 30 degress or lower because if i lift it up, the cables freeze. if i try to lower the lever it goes down but the pads are still locked against the rotor. previuos owner had honda change the calipers at aorund 100. and experience same problem many times.
2. b/c of this the other day i put my car on a steep driveway ramp n i left it in 1st gear. i get out n a few seconds later, the car rolls back a few inches n stops. then it does it again. i quickly got in my car n steeped on the brake. again it did the same in reverse gear too.
any diognoisis would be helpful from you guys thank you very much
Old Dec 4, 2005 | 02:15 PM
Chiovnidca's Avatar
Default Re: frozen E-brake. gear slips when parked!! (SIMATIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">
any diognoisis would be helpful from you guys thank you very much</TD></TR></TABLE>
Moisture in an e-brake cable freezing maybe?
Old Dec 4, 2005 | 04:38 PM
Jxi8s2k's Avatar
yo the same **** happened to me. i left my e-brake on and i think the pads froze too. i had to go somewhere so i had to burn up the drum brakes. i thought it froze cuase it rained the day before and i left my car outside the garage.
Old Dec 4, 2005 | 04:45 PM
kawgomoo's Avatar
Default Re: frozen E-brake. gear slips when parked!! (Jxi8s2k)
happens to my accord all the time when it gets cold. i presume the problem is the cables. lube the living **** out of them... car mechanics will probably look at you funny. talk to someone that ride/races dirt bikes or something and they should be familiar with the procedure.
basically disconnect the cables where 2 become one at the ebrake, slide a piece of hose over the cable jacket and secure with hose clamp. fill the hose {should be clear} with brake clean, stick an air fitting in the end and blow the solution through the cable. repeat several times. now fill the tube with cable lube {avail from motorcycle store} and do the same thing... this should solve the problem.
obviously lube all pivot poits etc. anywhere grease once was and has been replaced by dirt and water will possibly lock up when cold.
Old Dec 5, 2005 | 02:07 AM
Jxi8s2k's Avatar
Default Re: frozen E-brake. gear slips when parked!! (kawgomoo)
damn..seems like a lot of work. all i do is leave it in first gear and pull up the brake just a little bit
Old Dec 5, 2005 | 02:10 AM
YeuEmMaiMai's Avatar
replace the cable. it will solve the problem
Old Dec 5, 2005 | 08:05 PM
SIMATIC's Avatar
Default Re: frozen E-brake. gear slips when parked!! (YeuEmMaiMai)
can i do the cables myself? is it hard?
Old Dec 5, 2005 | 08:06 PM
it's not that hard if you are mechanically inclined takes about an hr or so
sidirtybird
Honda Civic (2006 - 2015)
20
May 16, 2023 03:10 PM
TexasCheddar
10
Oct 14, 2013 03:10 PM
HondaH22A
May 22, 2009 09:37 PM
Mikey3000
Sep 24, 2007 08:17 AM
S2KJ55
Honda S2000
34
Apr 26, 2006 05:10 PM
