sway bar question
i have a 1991 crx dx and i was wondering if it would be worth buying a 1992 integra oem rear sway bar... i can get one from a friend right now for $20 with the brackets and bushings... -justin-
ps: i dont even think my car has a rear sway bar stock
I've read it here before, but the DA rear sway bar is the same size as the Si's. If not the 4dr DA had a fraction of a size larger.
The most common reccomendation I've seen here is to get the Suspension Technique rear sway bar.
And I also read that there was no need to upgrade the front sway bar, and that people agreed to go smaller in the front. Then again I've heard of the "No Front Sway Bar" reccomendation as well
use the 88-91 civic/crx sway bar BRACKETS in the rear with the DA rear bar. the DA bushings will bolt right onto the 4g brackets.
i had this setup in the past.
all models seem to have the holes on the frame FOR the brackets...but some are threaded and some are not
Andrew 825SM
Jul 7, 2003 01:19 PM
bw54867
Oct 14, 2002 06:51 PM
