How many harnesses under ef dash board?
We just bought a ef std bare shell and im in the process of installing all the wiring under the dash area and i seem to be missing alot of plugs .
I was under the impression that there was only one that goes across .
Is there another one that goes in the driver side foot well area cause i seem to be missing a few plugs like the cluster hazards and a few others
i'd save yourself a headache and just grab a whole body harness from a pick and pull..
it could possible be as simple as a major plug missing from the back of the fuse box though... you'll have to look at another stripped ef to see though - it's not an easy question to answer.
i put a crx si full harness every wire into a hatch so i think i can help you. there is the main body harness and the engine harness. but the body harness has several other harnesses that can be unplugged. there is a dash harness for the cluster clock and stereo that plugs in the fuse box and another plug ontop of the fuse box. and theres other ones for the turn signals and light switch by the steering wheel. but the tricky part is some harness wont plug into other year harnesses. but there will still be some plugs not used under the dash. pm me and i can help you out more. if your gonna change out the whole body harness its gonna be some work but if you do get an si one i have alot of extra harnesses laying around to.
Oscarasimov
13
Sep 19, 2012 10:33 PM
coreysef
May 17, 2010 04:15 AM
