brake lights
Old Dec 4, 2005 | 10:44 AM
md88hfcrx's Avatar
Default brake lights
on my girlfriends hatch i noticed that all but 1 brake light is out. all the running lamps work properly but when you hit the brakes only the passenger side illuminates brighter.
suggestions?
Old Dec 4, 2005 | 10:49 AM
Padawan's Avatar
Darth ModerVader
Default Re: brake lights (md88hfcrx)
Try replacing the bulbs.
Old Dec 4, 2005 | 10:51 AM
md88hfcrx's Avatar
Default Re: brake lights (Padawan)
the running lights work. they just dont get brighter. and the spoiler light (duckbill) doesnt work
Old Dec 4, 2005 | 10:55 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md88hfcrx &raquo;</TD></TR><TR><TD CLASS="quote">the running lights work. they just dont get brighter. and the spoiler light (duckbill) doesnt work</TD></TR></TABLE>
The brake light bulbs are a two filament bulb, more than likely one of the filaments is burnt out on the bulb. For the spoiler, it uses an LED light (several small lights), so if it's not working all together, I would check the wiring on it.
It seems highly unlikely that all the LEDs would go out at once.
Old Dec 4, 2005 | 10:56 AM
Padawan's Avatar
Darth ModerVader
The bulbs are dual-filament, so it's possible that the high wattage filament has burned out in them. However, since the third brake light doesn't work either, there may be some sort of wiring issue.
Old Dec 4, 2005 | 01:38 PM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The bulbs are dual-filament, so it's possible that the high wattage filament has burned out in them. However, since the third brake light doesn't work either, there may be some sort of wiring issue. </TD></TR></TABLE>
-Shane
Old Dec 4, 2005 | 01:57 PM
nocturnaldragon's Avatar
Its also a possiblility when they sliced into the wiring for the duck bill they broke the wire for the other lights somehow, its a possibility you may want to check out.
try swaping the bulbs from side to side that will be an easy cheap way to check your bulbs and wiring to see if there good.
racerx413
Sep 20, 2014 02:38 AM
Jccrew
Honda CR-V & Element
Mar 13, 2014 06:24 AM
AcuCrazy
Oct 28, 2008 11:27 AM
94civicoupe
Oct 16, 2006 06:09 PM
blaster834
11
Apr 26, 2004 09:05 PM
