how high are you reving your itr valves to?
Old Dec 4, 2005 | 10:35 AM
ATS*Mark's Avatar
OG triple OG
Default how high are you reving your itr valves to?
just curious how high you guys are reving your motors to that have stock itr valves. ive been taking the car to 9k because thats when the power stops but im sure there are some guys gonig higher.
Old Dec 4, 2005 | 10:55 AM
Supernatural's Avatar
Default Re: how high are you reving your itr valves to? (Hella_JDM)
search noob....
9200-9300 and thats pushing it...
Old Dec 4, 2005 | 12:47 PM
PURPLETERROR aka BIGMATT's Avatar
10.5k on stock b16a valves for 3 years not reccomended but ive done it numerous times. Oem valves are pretty strong
Old Dec 4, 2005 | 12:50 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how high are you reving your itr valves to? (NATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NATURAL &raquo;</TD></TR><TR><TD CLASS="quote">search noob....
9200-9300 and thats pushing it...</TD></TR></TABLE>
lol my bad
Old Dec 4, 2005 | 01:36 PM
clayton bigsby's Avatar
i used to hit 10k all day no problem with toda springs and port flow retainers
Old Dec 4, 2005 | 01:43 PM
drdisco69's Avatar
Even non-R valves are good for way more than 9300.
Old Dec 4, 2005 | 01:48 PM
BigAl's Avatar
Default Re: how high are you reving your itr valves to? (clayton bigsby)
There have been a number of documented failures of ITR inlet valves when taken over 9200 rpm
In the UK where the FIA class required standard valves in modified production road race cars this was the number one reason for engine failure .
When I was at Toda Japan their head engineer said exactly the same thing and recomended oem,non ITR inlets if going over 9200 in a road race engine .
I think Toda lists non ITR vinlet valves in the spec sheets fro toda b's, c's and killers
Old Dec 6, 2005 | 10:09 PM
oldskool teggy's Avatar
Default Re: how high are you reving your itr valves to? (BigAl)
good info
Old Dec 6, 2005 | 11:33 PM
b19coupe's Avatar
9,500.
Old Dec 30, 2005 | 08:24 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigAl &raquo;</TD></TR><TR><TD CLASS="quote">There have been a number of documented failures of ITR inlet valves when taken over 9200 rpm
I think Toda lists non ITR vinlet valves in the spec sheets fro toda b's, c's and killers </TD></TR></TABLE>
Never heard stock itr vavles breaking before.
Old Dec 30, 2005 | 08:29 AM
Used2beAb16's Avatar
Default Re: how high are you reving your itr valves to? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">10.5k on stock b16a valves for 3 years not reccomended but ive done it numerous times. Oem valves are pretty strong</TD></TR></TABLE>
Im pretty sure that b16 valves are ok, its the ITRs in question.
Old Dec 30, 2005 | 09:49 AM
Bradstard's Avatar
My motor is running stock ITR valves. It has seen 10,100 rpms on the dyno and power had not fallen off yet. On the street I keep my rev limiter on 9200 rpms and no problems. This motor has also seen 8 full HPDE track days with many trips to 10,000rpms on downshifts. ITR valves =
Old Dec 30, 2005 | 04:49 PM
hondaboyB18C1's Avatar
Default Re: how high are you reving your itr valves to? (Bradstard)
I have had my b16a to 9300rpm. just curious what you guys are using for cams to make power to 10000 rpm or are you just revving the hell out of it?
I have had USDM 97 ITR , Jun 2 , M22 and Toda B camshafts , none of which seem to make power past 8400rpm
Old Dec 30, 2005 | 05:01 PM
2k.civic.si's Avatar
Default Re: how high are you reving your itr valves to? (hondaboyB16)
so the non-r valves are stronger? why is this?
Old Dec 30, 2005 | 05:09 PM
THEUSED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB16 &raquo;</TD></TR><TR><TD CLASS="quote">I have had my b16a to 9300rpm. just curious what you guys are using for cams to make power to 10000 rpm or are you just revving the hell out of it?
??????</TD></TR></TABLE>
Judging by your signature your motor cant support the airflow needed for high rpm.
Boostage's Avatar
Default Re: how high are you reving your itr valves to? (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">so the non-r valves are stronger? why is this?</TD></TR></TABLE>
my guess would be becuse they are not hollow stem like itr valves.
Old Dec 30, 2005 | 05:29 PM
crx2nr822's Avatar
Default Re: how high are you reving your itr valves to? (Boostage)
I would be more worried about the retainers letting loose before the actual valves.......IMO.
Old Dec 30, 2005 | 07:35 PM
flesh199's Avatar
Default Re: how high are you reving your itr valves to? (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Judging by your signature your motor cant support the airflow needed for high rpm.</TD></TR></TABLE>
x2
Old Dec 30, 2005 | 08:06 PM
Hamstr323's Avatar
Default Re: how high are you reving your itr valves to? (flesh199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flesh199 &raquo;</TD></TR><TR><TD CLASS="quote">
x2 </TD></TR></TABLE>
x3
Old Dec 30, 2005 | 09:51 PM
Michael Delaney's Avatar
why do you think the valve is the limitation?
it's not like you're swapping to Titanium valves and saving a whole ton on valvetrain weight for rpm bounce. what do you think is the weight difference between ITR OEM intake valves and say a good stainless intake valve?
the valvespring is much more important since 90% of the problem is when coil bind occurs.
what was your reasoning to be concerned about ITR valves preventing you to rev to say 9500-10,000 rpm? I'm just curious.
Old Dec 31, 2005 | 05:22 AM
Boostage's Avatar
Default Re: how high are you reving your itr valves to? (Michael Delaney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">why do you think the valve is the limitation?
what was your reasoning to be concerned about ITR valves preventing you to rev to say 9500-10,000 rpm? I'm just curious.</TD></TR></TABLE>
Not true. LOOK HERE Ferreas Hollow stem valves boasts to be 20% lighter than SS valves. which in itself is already alot. titanium is even lighter according to this thread.. thats alot of weight savings. and after further research I did confirm that Ti valves are banned from certain classes. thats usually an indication that there is an advantage to running them
Old Jan 1, 2006 | 06:22 PM
delsolb16's Avatar
« Re: how high are you reving your itr valves to? (Bradstard) « » 5:49 PM 12/30/2005 Reply Edit
180 whp N/A B16
(stock head,airbox,TB,intake manifold)
hcp would solve that problem.
Old Jan 1, 2006 | 08:03 PM
aaroboost's Avatar
Default Re: how high are you reving your itr valves to? (delsolb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">
x3</TD></TR></TABLE>
ouch!! thats 6 TIMES!!!!
cibao2ner
Nov 24, 2010 11:39 PM
skata89
Sep 4, 2007 08:03 AM
vtecmike1
Feb 25, 2004 04:20 PM
Rhetoric
Dec 19, 2002 06:07 AM
