Any negative effects to switching to a larger TB?
Old Dec 4, 2005 | 06:12 AM
freeway's Avatar
Default Any negative effects to switching to a larger TB?
I'm wondering if there are any negative effects to switiching to a larger TB.
Old Dec 4, 2005 | 06:39 AM
Pompiuses's Avatar
Default Re: Any negative effects to switching to a larger TB? (freeway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freeway &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering if there are any negative effects to switiching to a larger TB.</TD></TR></TABLE>
If the TB is too big for your motor, you'll loose overall throttle response and low end power.
Old Dec 4, 2005 | 06:42 AM
freeway's Avatar
Default Re: Any negative effects to switching to a larger TB? (Pompiuses)
Thanks.
Old Dec 9, 2005 | 06:23 AM
BlUeHoOdCiViC99's Avatar
wa kind of motor for wa kind of throttle body for example got a b18c1 wiseco 11.8 comp std going to use SK2 proseries manifold with 66mm throttle is not to big or should i just stay with the OEM GSR one bump
Default Re: Any negative effects to switching to a larger TB? (BlUeHoOdCiViC99)
bump
Old Dec 9, 2005 | 06:26 AM
bump
Old Dec 9, 2005 | 06:45 AM
Pompiuses's Avatar
For my full bolt on JDM ITR motor (stock cams and internals), RPM services recommended a 70-68mm TB.
meanshyguy
Sep 28, 2008 08:28 PM
reactiondc2
Jul 17, 2007 09:03 PM
esteen2
14
Nov 2, 2006 06:32 AM
MysteriousGSR
Oct 24, 2005 02:34 AM
Maxboost00
Nov 27, 2004 09:09 PM
