could i use a p2t ecu in a 90 integra with ls/vtec?
whats up h-t. i am in need of some help. ok, i have a 90 integra which i am planning to do ls/vtec. i already have a complete b16 head, intake manifold, pr3 pistons and an p2t ob2b ecu all out of a 99 civic si. also have the ls block. my question is could i use the p2t ecu with a jumper harness ob2b-obdo to run in my 90 da? if i do this, do i have 2 run a second o2 sensor and which dizzy could i run with this set up besides the si. and also do i have to put a crank sensor? thanks if there is anything else i am missing please let me know. thanks again.
Yea you can do it but way more trouble than it's worth... Convert to OBD1 with a jumper harness and get a chipped P28 or equivalent ECU. Even if you used the Si ECU you would never be able to get rid of all the codes without a lot of extra wiring and headaches.
