Pad/Rotor help !!!!!!!!!!
Ok im looking a geeting new pads and rotors with SS lines.....i have Si front and rear brakes on the car now.....This is the set up i was Looking at Hawk Ceramic Performance Pads or the HPS Street pads....With Brembo Sport Slotted Rotors and Goodridge SS lines....seeing if this is a good setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Justin- »</TD></TR><TR><TD CLASS="quote">i have heard good things using the ss lines and hawk pads.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">so u should be fine using stock likes, rotors and pads in the rear</TD></TR></TABLE>
SS lines is the front with rubber in the back is still going to give you a softer pedal. SS lines all the way around is the way to go.
sounds like a good setup...haven't heard too much about the SS lines though...i just installed brembo slotted/drilled rotors with PBC i think pads...brakeing is so much smoother and braking on the free ways is alot easier...good luck with your setup bro...
square_1
13
Feb 26, 2008 12:54 AM
BuyBrakesdotcom
100
Nov 9, 2005 11:16 AM
tuong
Aug 26, 2004 06:29 AM
