Leaking coolant?? 93 civic,
93 civic lx, motor swap d15b vtec, ne ways, im drivin wheel fell off car fell on driver side front and scraped balljoint for 10 m, so i get car towed , i bought new wheel studs and as im changing them i notice a leak, its coolant, its coming from driver side top of oil pan, (bottom of timing cover,) what is it? please help, block cracked? headgasket, oil is clean and no coolant in it.
I have seen a ton of water pumps go out and **** coolant all over the place, if you have a 144k on that beast and didn't change the water pump with the timing belt(asuming you changed the belt) I wouldn't be supprised one bit if it was the water pump. Don't fret though, I think I payed 50 bucks at the dealer for mine, it's just the putting the time in that's all
Mine pees like a race horse! no jk it leaks slightly, it has been for 50K + miles. Timing belt has been done
Just keep fluid in it and it should be OK till you can get a new one put in.
accord1986
Jan 27, 2013 03:01 AM
