How to check 1988 crx dx engine codes
pull back the carpet on the passenger side where your feet are. There is a flashing light on the ECU that will tell you what codes you are throwing.
Long flash = 10
Short flash = 1
count the flashes and add the code up
Long flash = 10
Short flash = 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz »</TD></TR><TR><TD CLASS="quote">pull back the carpet on the passenger side where your feet are. There is a flashing light on the ECU that will tell you what codes you are throwing.
Long flash = 10
Short flash = 1
count the flashes and add the code up</TD></TR></TABLE>
on a CRX DX, they are all short flashes - there are no longs - just count the number of times it flashes - check them here:
http://tech.hybridgarage.com/tech/codes.html
Long flash = 10
Short flash = 1
http://www.hondata.com/techecucodes.html
This website will help you out alot also.check it out.
pin0y209
Jan 15, 2008 08:31 PM
